BuckRyp Posted April 14, 2012 Share Posted April 14, 2012 Ok, so my rear main seal went bad on my motor so a friend and i dropped the tranny and oil pan on the motor to replace it. Before doing any work the truck ran great no problmes at all, after the tranny and everything was back together there have been nothing BUT problems. First i started it up and ran like crap so i looked into it and the mass airflow sensor is compleatly messed up. found a new one online for $80 waiting for it to come in. now im haveing clutch problems. the clutch petal felt strange when i put the tranny back in so today i bled the lines and topped off the fluid now the pettle goes all the way to the floor and sticks there. nothing i can do fixes the isue. any ideas on what the problem is? i looked under the dash and everyting looks fine then i looked at the slave cylinder and it seams fine. no leaks anywhere not loosing fluid just will not stiffen up. cant even tell if it is working, idk please help Link to comment Share on other sites More sharing options...
adamzan Posted April 14, 2012 Share Posted April 14, 2012 Did you bleed the clutch dampener? It's on the passenger side of the firewall. Follow the line from the master cyl and you'll see it. Link to comment Share on other sites More sharing options...
nunya Posted April 15, 2012 Share Posted April 15, 2012 x2 on adamzans thought, no recoil back I would think would be due to still having some air in there. Had it happen on a previous HB once after replacing a master. Took a couple bleeds to get it solid fluid the whole way through and did you try cleaning your MAF yet instead of instant replacement? http://www.nissanpathfinders.net/forum/index.php?showtopic=5194 Link to comment Share on other sites More sharing options...
BuckRyp Posted April 15, 2012 Author Share Posted April 15, 2012 nunya, the maf has a missing wire like thing between the 2 posts. and i will bleed the clutch through a few more times i did miss the dampener bleed. Ill try that in the morning its cold and windy out. thank you for the info! hope to be driving her soon Link to comment Share on other sites More sharing options...
nunya Posted April 15, 2012 Share Posted April 15, 2012 I guess cleaning won't solve THAT issue! Link to comment Share on other sites More sharing options...
