qatcool Posted March 5, 2012 Share Posted March 5, 2012 I always read here about over drive, I have a 2002 pathfinder but I don't see any switch for OD? Can somebody tell me where to look at. Link to comment Share on other sites More sharing options...
WOT Posted March 5, 2012 Share Posted March 5, 2012 Left side of the shift knob Link to comment Share on other sites More sharing options...
devonianwalk Posted March 5, 2012 Share Posted March 5, 2012 If the over drive is switched off you will see an indicator on the instrument panel indicating that it is off. Link to comment Share on other sites More sharing options...
Towncivilian Posted March 6, 2012 Share Posted March 6, 2012 Link to comment Share on other sites More sharing options...
kdj Posted March 6, 2012 Share Posted March 6, 2012 As an added note the manual says...For driving up or down long slopes where engine braking would be advantageous, push the overdrive switch. The O/D OFF light illuminates. When cruising at low speed or climbing a gentle slope, you may feel uncomfortable shift shocks as the transmission shifts between 3rd and overdrive repleatedly. In this case press the overdrive switch. The O/D OFF indicator light comes on at this time. Just remember to turn it back on or your gas mileage will be even less than "normal". Link to comment Share on other sites More sharing options...
qatcool Posted March 7, 2012 Author Share Posted March 7, 2012 (edited) I don't have that switch!!,,,Is that normal....Is this also the reason that I feel the shift shock? Edited March 7, 2012 by qatcool Link to comment Share on other sites More sharing options...
Towncivilian Posted March 7, 2012 Share Posted March 7, 2012 That is very strange indeed. Can you post a photo of your shifter? Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 7, 2012 Share Posted March 7, 2012 Maybe it's missing because it's not a North American model??? Assuming the Pathfinder in question is equipped with an automatic transmission (not a manual), how many forward gear shift positions are there on the shifter? Link to comment Share on other sites More sharing options...
Towncivilian Posted March 7, 2012 Share Posted March 7, 2012 I believe all R50s automatic gasoline Pathfinders have an RE4R01A transmission of some sort, which all have overdrive. If the OP can post the transmission model located on the certification plate on the right side of the firewall, that would help. Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 8, 2012 Share Posted March 8, 2012 (edited) I believe all R50s automatic gasoline Pathfinders have an RE4R01A transmission of some sort, which all have overdrive. Yah, but maybe his gear selector lever says "PRND321" while N/A models are "PRND21" with the OD on/off button... Just throwin' out crazy ideas... Edited March 8, 2012 by XPLORx4 Link to comment Share on other sites More sharing options...
qatcool Posted March 8, 2012 Author Share Posted March 8, 2012 I believe all R50s automatic gasoline Pathfinders have an RE4R01A transmission of some sort, which all have overdrive. If the OP can post the transmission model located on the certification plate on the right side of the firewall, that would help. This is what I got from the nameplate RE4 RO1A H646, and my shift PRND12, it's made in Japan. Link to comment Share on other sites More sharing options...
qatcool Posted March 8, 2012 Author Share Posted March 8, 2012 This is what I got from the nameplate RE4 RO1A H646, and my shift PRND12, it's made in Japan. Link to comment Share on other sites More sharing options...
Towncivilian Posted March 8, 2012 Share Posted March 8, 2012 Can you post a picture of the shifter? Link to comment Share on other sites More sharing options...
