trailing arm bolts
new2rice
The bolts don't need to be replaced but it's always good to have them in case they break upon removal like mine did lol.
There are 2 different lengths so here you go.
Frame side bolt is M14 X 1.5 X 3.5" long.
Axle side bolt M14 X 1.5 X3.75" long.
Make sure to get grade 8 instead of 5 since its a pretty important bolt lol.
Edited by wd21overland
If you are going to go through all of the trouble of pulling them off to swap the bushings, (they are certainly a PITA)...
Have you considered beefing them up, or replacing them with some heavier units?
Do you have a welder, or access to one? Some DOM tubing and your set...
Welcome to the forums!
