SchizophrenicMC Posted January 22, 2012 Share Posted January 22, 2012 I'm definitely adding that little modification when the Pathfinder is fixed. Results will be hilarious. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 22, 2012 Share Posted January 22, 2012 I'm definitely adding that little modification when the Pathfinder is fixed. Results will be hilarious. Can't wait to see. Link to comment Share on other sites More sharing options...
crue313 Posted January 22, 2012 Author Share Posted January 22, 2012 well it looks like im going to definitely give the seafoam a try. It doesn't look like it could hurt as long as I don't over do it in the vacuum line and some in the gas tank I'm sure would make a good improvement with the idle. Link to comment Share on other sites More sharing options...
devonianwalk Posted January 22, 2012 Share Posted January 22, 2012 Good luck! Link to comment Share on other sites More sharing options...
JamesRich Posted January 23, 2012 Share Posted January 23, 2012 Just a tip about running it through the vacuum line. Don't use the brake booster line, try to get it through the PCV line even if you have to add a piece of hose to it to reach. The sludge your trying to clean out all came in as oil vapors through the PCV. By poring the seafoam in through the PCV your starting at the source of the sludge. James Link to comment Share on other sites More sharing options...
MY1PATH Posted January 23, 2012 Share Posted January 23, 2012 A while back my friends were talking me into taking the pathy to the drag strip. I wanted to set up that very Smoke screen setup SchizophrenicMC is talking about but with water instead so I could at least have something to show for my raging 20 second car lol. Water is cheaper and smells better. So I have less guilt about smoking as often as I want. Link to comment Share on other sites More sharing options...
918pathy Posted January 23, 2012 Share Posted January 23, 2012 Isnt there a spray version of Seafoam, one that you can spray into the intake? If so would you access the intake via the air intake? Link to comment Share on other sites More sharing options...
MY1PATH Posted January 23, 2012 Share Posted January 23, 2012 Isnt there a spray version of Seafoam, one that you can spray into the intake? If so would you access the intake via the air intake? Yes, its called deep creep throttle body cleaner. It does not clean the engine, it is meant to clean up the mechanical parts of the throttle when the engine is turned off. Link to comment Share on other sites More sharing options...
