01KJRPath Posted January 10, 2012 Share Posted January 10, 2012 I have an 01 that I am getting clucking noises when accelerating. I believe it might be that a motor mount has failed. No noise from car over large bumps or stopping. Anyone have a write-up, tip, or advice for replacing them. TIA Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 10, 2012 Share Posted January 10, 2012 First, check that the motor mount has actually failed by opening the hood, then while seated in the driver's seat, firmly apply the brake, shift into 1st gear and watch for extreme engine movement while you press the gas pedal. Do the same in reverse. If you see the engine move up or down more than 3/4" then you have a failed motor mount. If the engine doesn't seem to move too much, the clunk may be caused by something else. If it is indeed a motor mount, you will need to remove the front differential to access them. Link to comment Share on other sites More sharing options...
01KJRPath Posted January 10, 2012 Author Share Posted January 10, 2012 (edited) First, check that the motor mount has actually failed by opening the hood, then while seated in the driver's seat, firmly apply the brake, shift into 1st gear and watch for extreme engine movement while you press the gas pedal. Do the same in reverse. If you see the engine move up or down more than 3/4" then you have a failed motor mount. If the engine doesn't seem to move too much, the clunk may be caused by something else. If it is indeed a motor mount, you will need to remove the front differential to access them. Motor moves more than 3/4" when in reverse. You can feel the the clunk when the car shifts. I was planing to replace all the mounts, and was hoping for a nice easy R&R. Removing the diff is a bit of a pain, but more time consuming than difficult. Thanks Edited January 10, 2012 by 01KJRPath Link to comment Share on other sites More sharing options...
WOT Posted January 11, 2012 Share Posted January 11, 2012 Maybe have some fun and fabricate strut mount to hold the engine.... You could probably build something off of a DIY crossmember link to the transmission and hold everything pretty solid Just ideas... Link to comment Share on other sites More sharing options...
01KJRPath Posted January 11, 2012 Author Share Posted January 11, 2012 Maybe have some fun and fabricate strut mount to hold the engine.... You could probably build something off of a DIY crossmember link to the transmission and hold everything pretty solid Just ideas... Not building a racecar here. Just want to keep the motor in the car. Link to comment Share on other sites More sharing options...
WOT Posted January 11, 2012 Share Posted January 11, 2012 A simple link securing it to the chassis makes a racecar? Link to comment Share on other sites More sharing options...
01KJRPath Posted January 12, 2012 Author Share Posted January 12, 2012 A simple link securing it to the chassis makes a racecar? No, but I see no real need to add a link like that. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 13, 2012 Share Posted January 13, 2012 I remember someone on here welded chain between the top and bottom plate of a motor mount. There's apparently a lot of stress on the mounts when you're in 4LO, and the chain steps in where the rubber would fail. Link to comment Share on other sites More sharing options...
Kingman Posted January 13, 2012 Share Posted January 13, 2012 Mr.510. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 14, 2012 Share Posted January 14, 2012 ^That's what I was thinking of. Thanks. Link to comment Share on other sites More sharing options...
01KJRPath Posted January 14, 2012 Author Share Posted January 14, 2012 I haven't seen many posts about motor mount replacement. Which leads me to believe that the mounts are sufficient for 100k+ miles. Link to comment Share on other sites More sharing options...
