Installing Heated Seats
AdamM
by the way, where is the location of the factory heated seat switch ?
It goes in the center console. I have all options but heated seats, and the two blank plates in the center console are where the switches would be.
  • 3 weeks later...
i have a '94 se with EVERYTHING. Heated leather, adjustable shocks etc...... i also have a '95 se base. i took out the leather heated seats today to get ready to swap them into my '95. the '95 DOES NOT have the wiring harness built into it from the factory. in fact, there apears to be a facgtory splice connection invloved. also the computer module is differant. in order for me to do the swap, the computer mod(which has a bigger wiring connection) and all the wires, added to via plug in and splices, will need to be taken out of the '94 to replace those in tbe '95. i thought that it would be easier, alrady wired from the facorty with easy plug ins, but it appears not to be the case. good luck to all with your retro!
  • 10 years later...
