pathfinder tires / lift info
88MudFinder
Hey , im new to this forum and didnt see anything on this so heres my question.
with only just a 3" body lift whats the biggest size tires i can get?
Right now i have 31s with no lift and they dont rub at all even when im offroad.
Thanks!
Wow! I think this may have been a horrible hint to search.... ROFL
The general rule is you can fit 33x12.50's with a 3" SL and a 3" BL.
You can run 33x10.50's at stock height though.
Edited by silverton
Depends on how wide you go and if you want too cut the fenders.
It you want skinnys and your ok with cutting I say a 37x10.5 will fit. I mean really, you can fit 35s on HB's with no lift and lots of cutting or 44"'s** with 7 inchs of lift and cutting (but driving on a curb stuffs them) If you dont believe me I'll find the pics of the hb on 44s.
A 33x10.5 will fit stock.
A 33x12.5 needs 3+3* and some triming.
* Some folks consider a T-bar crank and new rear coils a 3" lift.
** your IFS wont live in anything other then mud with tires bigger then 33x12.5 or skinny 35's.
I have a 3" body lift and cranked up my torsion bars about an inch and a half over stock and I put these on today. :)
33x12.5x15 goodyear duratrac (close to true 33"). on very low offset steel 15x10 rims. I did do some fender trimming though! :P
