lint Posted September 3, 2011 Share Posted September 3, 2011 (edited) So I'll soon be removing & replacing my muffler to repair a rust spot under the rear seat. I'm wondering if the new black fibre gasket needs some sort of wet sealer (RTV?) or does it just go on and seals as a result of the bolts compressing it? Also, does anyone know the bolt size & pitch of the bolts from muffler to Cat? I need the bolts onhand just in case something breaks as I live out-of-town. Thanks! d edit: '94 WD21 Edited September 3, 2011 by lint Link to comment Share on other sites More sharing options...
sewebster Posted September 3, 2011 Share Posted September 3, 2011 You aren't required to use a sealer. Probably wouldn't hurt too much if you did, but I never had. I have no idea what the oem spec bolts are, but I've just been using a bag of M10x1.5 for my exhaust work and it seems fine. Link to comment Share on other sites More sharing options...
adamzan Posted September 3, 2011 Share Posted September 3, 2011 Putting a small coat of copper rtv on the gasket couldn't hurt. Also you could take some sandpaper and clean up the flange surface for better adhesion. Link to comment Share on other sites More sharing options...
lint Posted September 3, 2011 Author Share Posted September 3, 2011 Thanks guys! Link to comment Share on other sites More sharing options...
