Silverfox03 Posted August 10, 2011 Share Posted August 10, 2011 Hey guys i just bought a brand new cb radio from radio shack, i know you guys prolly would have recommended something else but im sure it will work fine with the amount that ill be using it (includes lifetime warrantee.) i was curious to see your guys's cb setups with the antenna placement as well as the placement of the box inside the car. Any advice on where to mount the antenna it is a 27incher. Link to comment Share on other sites More sharing options...
Rick13 Posted August 10, 2011 Share Posted August 10, 2011 (edited) I did about 3 months of research and decided I wanted my dash mounted (so I bought this CB specifically for it's dimensions): Antenna is 2' FireStik that is on a hood channel mount - not the best location, but it works great for my purposes. Generally, antennas work best up high surrounded by a flat surface (like smack in the center of your roof). Edited August 10, 2011 by Rick13 Link to comment Share on other sites More sharing options...
silverton Posted August 10, 2011 Share Posted August 10, 2011 I know this is R50 specific, but thought I'd toss in my input as well! I like your install Rick! I may do the same as a WD21 has a Double-DIN spot. As of right now, my radio is wedged between the passenger seat and the center console. It was a quick and dirty job and just haven't gotten around to making it permanent. I'll have to see if I can make it work under my stereo. As for the antenna I used a standard mirror mount clamp style, and longer hardware, and used an existing hole in my tire carrier. But as rick said, the more of the antenna that is above the roof line (preferably in the center) the better. The flat surface is considered a "ground plane". You see semi-trucks and some pick ups with two antennas because they don't have a proper ground plane so one of the antennas acts in place of it. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted August 11, 2011 Share Posted August 11, 2011 There are several threads that have covered this very topic. Try searching CB radio, CB location, CB mount, ect. Here is the one with, what I think, is the best all around info.... http://www.nissanpathfinders.net/forum/index.php?showtopic=20030&st=0&p=344381&hl="cb%20radio"&fromsearch=1entry344381 Link to comment Share on other sites More sharing options...
bammbritt Posted August 13, 2011 Share Posted August 13, 2011 (edited) Here is my set up, cb by bammbritt, on Flickr cb2 by bammbritt, on Flickr I use the "Little Wil" Wilson CB Magnet Mount Antenna. I got it from amazon for 35 bucks, it haas the coaxial cable and I just ran it through the back hatch with the antenna on the roof towards the back. I like being able to take it down if I need to. Works really good for such a short antenna. The fun thing is the PA function, I mounted a trumpet speaker in front of the radiator and ran the wire to the CB through the hole in the firewall for my amp power cord. Edited August 13, 2011 by bammbritt Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted August 15, 2011 Share Posted August 15, 2011 Here's my set up..... 4ft Firestik mounted on my KMA Bumper Link to comment Share on other sites More sharing options...
180sx Posted August 16, 2011 Share Posted August 16, 2011 I love your Pathy OffTour...Love it. Wanna trade? Lol. Jose Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted October 20, 2011 Share Posted October 20, 2011 very clean installs! Still looking. I know someone stuffed one in that useless area on the bottom.... Link to comment Share on other sites More sharing options...
trenton163 Posted November 25, 2011 Share Posted November 25, 2011 Here is my set up, cb by bammbritt, on Flickr cb2 by bammbritt, on Flickr I use the "Little Wil" Wilson CB Magnet Mount Antenna. I got it from amazon for 35 bucks, it haas the coaxial cable and I just ran it through the back hatch with the antenna on the roof towards the back. I like being able to take it down if I need to. Works really good for such a short antenna. The fun thing is the PA function, I mounted a trumpet speaker in front of the radiator and ran the wire to the CB through the hole in the firewall for my amp power cord. I have that same stereo !! Link to comment Share on other sites More sharing options...
Pezzy Posted November 25, 2011 Share Posted November 25, 2011 Link to comment Share on other sites More sharing options...
