NissanNismoZ Posted February 25, 2011 Author Share Posted February 25, 2011 You might want to replace most of those hoses while you've got it apart. The dealer can likely order ones that will fit properly, for a bit of a premium. true.. the hoses underneath the intake are great but its just a few of the bigger hoses.. but ill try autozone first.. im hoping they arent too much. Link to comment Share on other sites More sharing options...
adamzan Posted February 25, 2011 Share Posted February 25, 2011 If it were me I would replace all of the hoses that would be otherwise hard to access while you are in there. Unless money is tight this is a good idea. It has saved me many headaches. Link to comment Share on other sites More sharing options...
Indigent Posted February 26, 2011 Share Posted February 26, 2011 (edited) I am kinda surprised that no one brought this up, so I will. The #5 injector is not under the plenum... Hope you didn't go through all that for the wrong injector. Also, from what you described, the part you are looking for is called CAP-RUBBER 16619-53J00 in FAST. Those don't feel like rubber to me though, the feel aluminum. Check this pic. Nissan Parts Zone has them for around $3.50 right now. The number I think you are talking about is 17521H (the H kinda looks like a K, but it's an H). That pic is in section 164, under "B Fuel and Engine Control" Edited February 26, 2011 by Indigent Link to comment Share on other sites More sharing options...
k9sar Posted February 26, 2011 Share Posted February 26, 2011 yep... I've got those. PM me with your address and I'll get one on the way Link to comment Share on other sites More sharing options...
NissanNismoZ Posted February 27, 2011 Author Share Posted February 27, 2011 I am kinda surprised that no one brought this up, so I will. The #5 injector is not under the plenum... Hope you didn't go through all that for the wrong injector. Also, from what you described, the part you are looking for is called CAP-RUBBER 16619-53J00 in FAST. Those don't feel like rubber to me though, the feel aluminum. Check this pic. Nissan Parts Zone has them for around $3.50 right now. The number I think you are talking about is 17521H (the H kinda looks like a K, but it's an H). That pic is in section 164, under "B Fuel and Engine Control" you're kidding me right? i REALLY hope they just miscounted or something.. Link to comment Share on other sites More sharing options...
k9sar Posted March 3, 2011 Share Posted March 3, 2011 Sorry... forgot to notify you. The cap and a pair of screws are on the way first class USPS. It was less than a buck and a half for postage so don't worry about it. 1 Link to comment Share on other sites More sharing options...
NissanNismoZ Posted March 16, 2011 Author Share Posted March 16, 2011 Thanks! i have it all put together now..but one more question.. there's 3 lines going to the big waffle hose from the air filter to the throttle plate.. 2 big hoses.. and one little one.. apparently someone lost it (if its needed i can pull one from another engine, no biggie) but..is it an important vacuum line? i cant figure out where it would go.. the pathy is ready to go, other than that one little tiny vacuum line.. it doesnt go to the breather box.. all those lines are hooked up.. any ideas? Thanks! (I know, i probably should have taken a picture before i left shop.) Link to comment Share on other sites More sharing options...
sewebster Posted March 16, 2011 Share Posted March 16, 2011 I think it goes to the EGR solenoid? Can't remember exactly right now. At the very least you would need to plug vacuum leaks. I would replace it. Presumably the FSM has vacuum schematics too. Link to comment Share on other sites More sharing options...
NissanNismoZ Posted March 16, 2011 Author Share Posted March 16, 2011 I think it goes to the EGR solenoid? Can't remember exactly right now. At the very least you would need to plug vacuum leaks. I would replace it. Presumably the FSM has vacuum schematics too. Sweet! that's where it went! Thanks. Link to comment Share on other sites More sharing options...
