Drive shaft torque specs
zelix
Go to the hardware store. They are nothing special, just grade 8.8 bolts. Bring one with you and match them up...
Truck is not with me... so i don't know exactly what to get.
Ok, so wait until you get to the truck...?
Truck is at my school... We are hoping to have the truck finished and mobile tomorrow. I wont have a vehicle available to get a bolt from school besides the pathfinder if its finished... You think i can drive it to the auto store?
might you own a bicycle? :whip:
Torqueing is generally a "do as I say-not as I do" type subject. Correct numbers were given (multiple times by many), honestly if anyone wants to listen or ignore them it ain't my problem. Our job has been completed. You can only lead the Kyle horse to the water...
its not that important for the torque spec, i have been using a 3/8 impact gun and havent had a problem yet.
a GOOD IR 3/8 impact only puts out 75 ft lbs when new. at 110PSI
so if you have a lesser quality, or older one, ow lower air pressure..
Your only torquing it to aroudn 60-65 ft lbs.
which is within range.
