Chicano2005 Posted November 29, 2010 Share Posted November 29, 2010 (edited) I have an Immobilizer device on my truck. It could be OEM because it says on the manual. It sometimes enables itself and i've tried to enable it but i have failed. So anyways, i would really love to have it enabled at night. does anyone have one, and/or knows how to enable it? Edited November 29, 2010 by Chicano2005 Link to comment Share on other sites More sharing options...
01silvapathy Posted November 29, 2010 Share Posted November 29, 2010 Wait what? Do you mean the shift lock? Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 29, 2010 Author Share Posted November 29, 2010 Wait what? Do you mean the shift lock? NO! Its basically a starter kill switch. when its enable(activated) it doesn't let the engine crank. Link to comment Share on other sites More sharing options...
93xe Posted November 29, 2010 Share Posted November 29, 2010 your truck comes stock with a transponder immobilizer system, which is a chip in the key....so that the vehicle can only start with the matching chipped key this is always enabled whenever the vehicle is not running if you have an aftermarket starter kill installed, there would most likely be a small toggle switch hidden somewhere or it could be wired to an aftermarket alarm system Link to comment Share on other sites More sharing options...
skulptr Posted November 29, 2010 Share Posted November 29, 2010 is that what the K shaped symbol is on my nissan oem key? Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 29, 2010 Author Share Posted November 29, 2010 your truck comes stock with a transponder immobilizer system, which is a chip in the key....so that the vehicle can only start with the matching chipped key this is always enabled whenever the vehicle is not running if you have an aftermarket starter kill installed, there would most likely be a small toggle switch hidden somewhere or it could be wired to an aftermarket alarm system well, now that you mention "chip in key" makes me wonder. i start my truck every time with no problem. I have an LED light under the SECURITY light that flashes rapidly when its activated. when that happens i just push the button to start it again. but i wanna know if some one has the same device. and if so how do they activate it? Link to comment Share on other sites More sharing options...
skulptr Posted November 30, 2010 Share Posted November 30, 2010 pictures would help. never heard of another led under the security one. i have an led under the security, but thats my aftermarket system. Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 30, 2010 Author Share Posted November 30, 2010 pictures would help. never heard of another led under the security one. i have an led under the security, but thats my aftermarket system. ima get some in a few hours! also pictures of the manual(01) sup[porting the immobilizer. Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 30, 2010 Author Share Posted November 30, 2010 2001 owners manual Link to comment Share on other sites More sharing options...
skulptr Posted November 30, 2010 Share Posted November 30, 2010 that is not an oem light/switch Link to comment Share on other sites More sharing options...
TooQForYou Posted November 30, 2010 Share Posted November 30, 2010 Yeah, that looks/sounds aftermarket. The factory 'immobilizer', like 93xe said above, is just that the vehicle won't start without the chip key. Link to comment Share on other sites More sharing options...
DanAK Posted November 30, 2010 Share Posted November 30, 2010 (edited) Yeah, that looks/sounds aftermarket. The factory 'immobilizer', like 93xe said above, is just that the vehicle won't start without the chip key. Yes allowing for Nissan to collect big bucks whenever someone loses a key! I hate dealers Edited November 30, 2010 by DanAK Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 30, 2010 Author Share Posted November 30, 2010 cool guys thanks! but all i wanted to know its how to arm it its arms itself randomly i wanna gain control! Link to comment Share on other sites More sharing options...
93xe Posted November 30, 2010 Share Posted November 30, 2010 I have an LED light under the SECURITY light that flashes rapidly when its activated. when that happens i just push the button to start it again. but i wanna know if some one has the same device. and if so how do they activate it? where is this button you are pressing? that led under the security light is definitely aftermarket, although could be dealer installed in the aftermarket 12v world a rapid flashing led usually means the aftermarket alarm is self arming, or passive arming itself, but it also sounds like you could have just a basic starter kill installed Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 30, 2010 Author Share Posted November 30, 2010 where is this button you are pressing? that led under the security light is definitely aftermarket, although could be dealer installed in the aftermarket 12v world a rapid flashing led usually means the aftermarket alarm is self arming, or passive arming itself, but it also sounds like you could have just a basic starter kill installed is this same button! when i trun off the truck it rapidly flashes for a couple of seconds thats it. when it activates itself it flashes rapidly until i press it and turn the truck on. Link to comment Share on other sites More sharing options...
skulptr Posted November 30, 2010 Share Posted November 30, 2010 you need to dig around under the dash, and look for a brain of some sort, a computer module that, where and how its placed, would obviously not be installed by the factory. finding that brain, is the ONLY way to find out how to arm/disarm it, since you'd be able to look up a manual for it. in most cases, arming and disarming is as simple as using the key in the drivers door to lock and unlock it, without the aftermarket fob Link to comment Share on other sites More sharing options...
93xe Posted November 30, 2010 Share Posted November 30, 2010 yea that is definitely an aftermarket starter kill.... try one of these combinations.... turn the ignition on (2 clicks) and hold that button in for a few seconds turn the ignition on and off and then hold the button in turn the ignition on (2 clicks ) and press the button once or turn the ignition on and off and press the button once if any of these result in the led lighting up solid, the unit is in valet mode and shouldn't arm itself on you anymore like skulptr said you would really need to dig around and find the brain, which is mostl likely right up under the driver side dash, to find exactly what model alarm it is and find out how to permanently disarm it, or just pull the power fuse going to the brain if you find it Link to comment Share on other sites More sharing options...
Chicano2005 Posted November 30, 2010 Author Share Posted November 30, 2010 Thanks again guys! I will dig around and see what up. I'm not good in wiring (although i love it) but i will give it a try and look around for the brain. it does work which i what i like. i wont remove it. I repeat "all i wanna know is how to arm it on demand". it just does it randomly and when it does all i do i press the button and off we go! Link to comment Share on other sites More sharing options...
