Replacing the radiator on an R50 VG33E
Timmons
Need to replace my radiator and need some advice on how to do it. Didn't see a pinned topic on it. Anyone have a PDF file on this or instructions? I was quoted some ridiculous amount of money to have this changed so I figure, buy the radiator for $130.00 and put it in myself.
with engine cold
remove lower cooling housing
remove rad cap
remove drain in rad or lower hose
remove upper hose
remove overflow tube
remove upper rad mounts
remove rad
install cooling housing to new rad
then reverse the rest of the steps
takes like 30 min to do, no technician should charge more than $20-80
any new radiatior is an upgrade from the original, since they get packed with stuff. but as far as a better radiatior, not really. theres oem and premium replacement, and ive looked at them both, and saw no difference.
