bradh79 Posted November 20, 2010 Share Posted November 20, 2010 (edited) can someone tell me how many washers/shims and the size i need when i crank my torsion bars up 2 inches or direct me to the guide cos i cant find it anywhere its a 1990 nissan terrano thanks in advanced brad Edited November 20, 2010 by bradh79 Link to comment Share on other sites More sharing options...
nunya Posted November 20, 2010 Share Posted November 20, 2010 That's kinda a hard one as everyones truck is a little different... Link to comment Share on other sites More sharing options...
silverton Posted November 20, 2010 Share Posted November 20, 2010 That's kinda a hard one as everyones truck is a little different... What he said, no two trucks align the same way. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 20, 2010 Share Posted November 20, 2010 (edited) yes, its not a set number and driveway alignments are not easy and far from perfect. The FSM has a chart that states recomened shim thickness per the number of degrees camber and castor ajustment you need to correct. But now you need a tool to measure those 2 angles accurately and Castor is pretty hard to measure on your own. I've done driveway alignmets many times and I usually go and get them checked afterwards. Edited November 20, 2010 by MY1PATH Link to comment Share on other sites More sharing options...
FUELER Posted December 3, 2010 Share Posted December 3, 2010 shims? where do you put the shims? i lifted a 95 3" and did not use any shims Link to comment Share on other sites More sharing options...
Precise1 Posted December 3, 2010 Share Posted December 3, 2010 Between the UCA and the frame to get the camber in... B Link to comment Share on other sites More sharing options...
