Rough Idle, Shaking, And Check Engine Light
TexasPthFnder95
Ok so today my truck started shaking severly at start up and had a very rough idle and the check engine light would light up the after about 15 seconds it would clear up light would go off and truck would be normal :scratchhead: I really need some help with this its got me stumped i even changed the battery ground because it was almost corroded in half (the wire) i thought it could have something to do with it but apparently not...
Any trouble codes stored in the ECU?
I havent checked it yet it just started doing this today. And do you mean checking it with a scanner? Or is there another way, sorry ive never had engine troubles before but its probaly something to expect at 231,000mi :doh:
Sounds like what my truck was doing a little while ago. I checked codes (pinned thread in garage, go look) and came up with 51 injector circuit. I waited till I had a 1/4 tank left, put 2 bottles of injector cleaner in and haven't had a problem since.
Yes, you read the codes by counting the blinking lights on the ECU and then looking them up on a chart. Not the most convenient, but you don't need any tools or equipment to do it, just the code list. That is the best place to start most of the time...
Thanks for the help :aok: but where can i get the chart?
Mine was the 51 injector circut i changed the battery ground and connections and put fuel injector cleaner and octane booster haven't had problems with it again... I hope its good to go and it was just a random malfunction
Edited by TexasPthFnder95
with the truck running you should be able to press up under the EGR valve ( press on the diaphragm), when it is pressed up it should change the idle, if the diaphragm doesn't move that would be a problem as well
  • 1 month later...
