synthetic Posted October 28, 2010 Share Posted October 28, 2010 I have a 93 wd21, stock susp/chassis.. And, with that, what is the largest size tire that will fit w/ no rubbing? beyond that, where would it be recommended i pick up a body lift? I don't think I'd need more than two inch. Link to comment Share on other sites More sharing options...
andreus009 Posted October 28, 2010 Share Posted October 28, 2010 In stock setup the largest you can go without any issue is 31x10.50. These will rub the frame rail a little at full steering lock but it doesn't cause any issue. 4x4parts.com sells body lifts and suspension lifts. P.S. There a lot of threads about tire size and lifts around here. Try searching around. You can find a lot of interesting stuff. Link to comment Share on other sites More sharing options...
silverton Posted October 29, 2010 Share Posted October 29, 2010 If you wanna roll your fenders, you can squeeze 33x10.50's. Link to comment Share on other sites More sharing options...
RedPath88 Posted October 29, 2010 Share Posted October 29, 2010 You might want to review this recent thread, it should answer some of your questions and maybe even some you don't have yet http://www.nissanpathfinders.net/forum/index.php?showtopic=28385 As for a body lift, youare from.. hmm good question. What is "PHX" ? Anyway, local 4x4 shops are always a good place, you can also fine them at ruggedrocksoffroad.com and 4x4parts.com Link to comment Share on other sites More sharing options...
Precise1 Posted October 29, 2010 Share Posted October 29, 2010 Phoenix... B Link to comment Share on other sites More sharing options...
