Unsure of proper placement..
synthetic
I have a 93 wd21, stock susp/chassis.. And, with that, what is the largest size tire that will fit w/ no rubbing?
beyond that, where would it be recommended i pick up a body lift? I don't think I'd need more than two inch.
In stock setup the largest you can go without any issue is 31x10.50. These will rub the frame rail a little at full steering lock but it doesn't cause any issue.
4x4parts.com sells body lifts and suspension lifts.
P.S. There a lot of threads about tire size and lifts around here. Try searching around. You can find a lot of interesting stuff.
You might want to review this recent thread, it should answer some of your questions and maybe even some you don't have yet :D
http://www.nissanpathfinders.net/forum/index.php?showtopic=28385
As for a body lift, youare from.. hmm good question. What is "PHX" ?
Anyway, local 4x4 shops are always a good place, you can also fine them at ruggedrocksoffroad.com and 4x4parts.com
