O-Ring at fuel tank
amo1dun
89 Path auto
Kind of silly question...
swapped pumps and used a sending unit from a 95 cuz the sender was blowing the pump fuse..Noticed that the o ring stretched and isnt sealing the tank well so.....
Does anyone know if a leaking o-ring at the fuel tank can cause driveability problems..Symptoms are..Bogs out and wants to stall(never does tho), also hesitation, engine drops rpm when throttles steady ?? ECU doesnt throw any codes, Seems real bad at partial throttle but WOT seems ok for the most part.
thanks for any insight
The symptoms of a leaking O-ring are:
Smell of gas!
The bugging out at partial throttle part is sensor related. Clean your MAF sensor and possibly replace the O2 sensor and the coolant temp sensor.
Smell of gas!
I thought maybe it could have something to do with fuel pressure...thanks
