k9sar Posted September 8, 2010 Share Posted September 8, 2010 The headliner on the section running from the dome light to the drivers side has come off the underlying plastic and I almost lost it out the window. The covering is a vinyl, foam backed sheet of material that was apparently glued and tucked under the trim pieces. Anyone else had it come off? If so, how did you repair it? Looking for hints. I have an idea but was looking for experience on this topic. Link to comment Share on other sites More sharing options...
Kingman Posted September 9, 2010 Share Posted September 9, 2010 There's actually quite a few threads on this. Personally I would drop the whole thing and use 3M spray adhesive, and work the vinyl smooth of wrinkles. Link to comment Share on other sites More sharing options...
k9sar Posted September 9, 2010 Author Share Posted September 9, 2010 There's actually quite a few threads on this. Personally I would drop the whole thing and use 3M spray adhesive, and work the vinyl smooth of wrinkles. I guess I should use that search button, huh. My main concern was that a spray adhesive probably won't hold if the foam backing is deteriorating. Also looking for hints on removing the trim (cause I'm too lazy to search or read the FSM) Link to comment Share on other sites More sharing options...
1987caddy Posted September 9, 2010 Share Posted September 9, 2010 Mine was doing the same thing. I removed the vinyl and sanded all the glue and painted it. Mine has the gray interior. The paint matched the dark gray perfect. It's a textured paint by rust-oleum. Name is dark pewter at Walmart. Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 9, 2010 Share Posted September 9, 2010 i sprayed mine with black paint...and covered it at a later date...i liked it better painted black... Link to comment Share on other sites More sharing options...
Dowser Posted September 9, 2010 Share Posted September 9, 2010 (edited) Take a look at Tex's Rig in the members rides area as well. Page 3. He redid the whole interior with Arctic Camo. May try PMing him for a little info. Edited September 9, 2010 by Dowser Link to comment Share on other sites More sharing options...
nunya Posted September 9, 2010 Share Posted September 9, 2010 Bedliner! make sur eto send adamzan TONS of pics of it too! Link to comment Share on other sites More sharing options...
jj big shoe Posted September 9, 2010 Share Posted September 9, 2010 I tried redoing mine with vinyl but could never get it looking right. I ended up wraping it in the same material that I redid the headliner with. I got the headliner at Jo-Ann Fabrics and used their heavy-duty spray adhesive. It holds up better to heat than the 3M stuff. The material comes in gray or black and its foam-backed, pretty easy to work with. The problem with vinyl is the weight. Unless you get it really tight and secured well it'll sag. Stretching it around my old, brittle plastic pieces created more cracks and problems. Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 9, 2010 Share Posted September 9, 2010 Super 77 if u use sprat adhesive is all I can say....mean prank...spray it on someone's arm....don't rub t f it happens to u...get acetone or alcohol to clean it off Link to comment Share on other sites More sharing options...
Tungsten Posted September 9, 2010 Share Posted September 9, 2010 I used super 77 to attach that vinyl. The left side is perfect but the right side now has wrinkles so it looks like your grandma. Link to comment Share on other sites More sharing options...
1987caddy Posted September 9, 2010 Share Posted September 9, 2010 Use the 3m super 77 spray that has been mentioned. 3m has a super 90 that's in a green can but it will distort the vinyl. There is a chemical in it that reacts with certain materials and turns them to a gooey mess. Link to comment Share on other sites More sharing options...
nunya Posted September 9, 2010 Share Posted September 9, 2010 mean prank...spray it on someone's arm.... mean prank is ceran-wrappign someones toilet, thats jsut unpleasant... Link to comment Share on other sites More sharing options...
