shotzie417 Posted August 28, 2010 Share Posted August 28, 2010 i was just thinking,does anyone know if the intake manifold & supercharger from a vg33e frontier or extera would bolt up to the vg30 heads? isnt the vg30 and the vg33 the same thing just different bore size and cams/valves? Link to comment Share on other sites More sharing options...
MY1PATH Posted August 29, 2010 Share Posted August 29, 2010 the supercharger on the vg33er will bolt up to a vg30 heads. the castings are differant but all the ports, bolts, valves etc are in the same place. The vg33er uses an eaton m62 and I believe the eaton m90 will also bolt up. If you do this may I recomend you top off the oil on the SC (m62) before you install it. this is done with the snout facing skyward and removing the fill plug and impossible to do on the vehicle unless you hang it by the front bumper. this will keep it quieter longer. Link to comment Share on other sites More sharing options...
Toby Posted August 29, 2010 Share Posted August 29, 2010 They make kits to swap out your supercharger oil. I mean if you already have it out of the truck then by all means make sure you drain it out real good to change it. But if it's already in the truck you can use a syringe like thing to get it out. I don't know how many I've done to M90 units on 3800II GM engines. It's not a particularly fun job, but it's gotta be done. Also i'd make sure you turn it by hand a little a few times if you drain all the oil out like that. Just to get the new oil to coat the gears and all. But that's all personal preference. Link to comment Share on other sites More sharing options...
Astroc2002 Posted September 13, 2010 Share Posted September 13, 2010 the supercharger on the vg33er will bolt up to a vg30 heads. the castings are differant but all the ports, bolts, valves etc are in the same place. The vg33er uses an eaton m62 and I believe the eaton m90 will also bolt up. If you do this may I recomend you top off the oil on the SC (m62) before you install it. this is done with the snout facing skyward and removing the fill plug and impossible to do on the vehicle unless you hang it by the front bumper. this will keep it quieter longer. You mean the Eaton M90 Supercharger will bolt right up to the lower manifold which originally mates to the VG33ER heads, but can also bolt to the VG30E heads. If this is true, then I'm seriously having second thoughts about selling my apathy then. Let me know if the bolt patterns are the same on the M90 as the M62. Let me know. Thanx JB Link to comment Share on other sites More sharing options...
Tungsten Posted September 14, 2010 Share Posted September 14, 2010 it fits but have fun with nistune Link to comment Share on other sites More sharing options...
nismothunder Posted September 14, 2010 Share Posted September 14, 2010 Didnt they do this exact thing in a mag a while back,I'm nearly sure of it. Link to comment Share on other sites More sharing options...
MY1PATH Posted September 14, 2010 Share Posted September 14, 2010 build yourslef a megasquirt to go the the SC and forget about nisstune. megasquirt kits avg about $400 and they take a barometirc preassure reading right before each startup so they are self calibrating to altitute, temperature and weather. Not to mention total contol of everything..... Link to comment Share on other sites More sharing options...
Tungsten Posted September 14, 2010 Share Posted September 14, 2010 What about knock sensors and all that? Link to comment Share on other sites More sharing options...
MY1PATH Posted September 15, 2010 Share Posted September 15, 2010 What about knock sensors and all that? If you so choose you can include that into its programing. You could prolly even get it to run e85 making emissions testing a walk in the park. Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 15, 2010 Share Posted September 15, 2010 it fits but have fun with nistune What's the problem with Nistune? Link to comment Share on other sites More sharing options...
Tungsten Posted September 19, 2010 Share Posted September 19, 2010 (edited) It's not easy. See if you can copy the fuel map settings from a supercharged VG33ER motor, that might get everything close enough. Edited September 19, 2010 by Tungsten Link to comment Share on other sites More sharing options...
