alternator belt squeak
shooter
When I recently changed my t-belt I also changed the alternator and p.s. belts. The alternator belt has a little squeak to it at idle. Not a squeal from slipping, just a little slow speed squeak. When I spray a little belt dressing on it it will stop for a while then come back. Is there a good belt dressing or any other trick to stop this squeak? Thanks. I saw on youtube to hold a candle against the underside of it to stop a squeak by getting wax on it. Didn't work.
Belt dressing, waxing, water, and taking a wire brush to the side of the belt while the engine is running are only temporary fixes. You'll probably need a new belt, or you'll need to clean off the pulley real well. It could be glazed over and can't grab the belt as well as it should.
