Kyle94 Posted July 12, 2010 Share Posted July 12, 2010 Dont know if this has been asked before, i couldnt find anything that answered my problems... I took my pathy from Kelso to Portland the other day and had the A/C on the whole way there, pretty damn cold. The bad part, i kept smelling something like Anitfreeze... i dont know if it was that or just something else.... i was sweatin pretty bad that day... so... Link to comment Share on other sites More sharing options...
silverton Posted July 12, 2010 Share Posted July 12, 2010 you could have a pinhole leak in a hose that's spraying onto something hot so it evaporates right away and doesn't leave a puddle and the smell is getting in through the intake vents in the cowl. But... Link to comment Share on other sites More sharing options...
Kyle94 Posted July 12, 2010 Author Share Posted July 12, 2010 you could have a pinhole leak in a hose that's spraying onto something hot so it evaporates right away and doesn't leave a puddle and the smell is getting in through the intake vents in the cowl. But... hmmmm.... guess ill have to get the truck hot and see if i can see anything sprayin... Link to comment Share on other sites More sharing options...
MY1PATH Posted July 13, 2010 Share Posted July 13, 2010 sounds like a leak in the heater core. Yes I know you used cold but its the same ducting so odors still cary over from one core to the other. Link to comment Share on other sites More sharing options...
Kyle94 Posted July 13, 2010 Author Share Posted July 13, 2010 sounds like a leak in the heater core. Yes I know you used cold but its the same ducting so odors still cary over from one core to the other. well damn thats not good if so... i wonder if all the stuff i sucked out of the blower fan area unclogged a hole, or i somehow poked a hole in the mofo... Link to comment Share on other sites More sharing options...
GrimGreg Posted July 13, 2010 Share Posted July 13, 2010 (edited) well damn thats not good if so... i wonder if all the stuff i sucked out of the blower fan area unclogged a hole, or i somehow poked a hole in the mofo... Put a bottle under the drain on the vent system (firewall on passenger side) and see what color the fluid coming out is. If it is clear, no prob just normal condensation, green, you got a leak. You'll need to run the truck with the AC on a while to get some drainage. Edited July 13, 2010 by GrimGreg Link to comment Share on other sites More sharing options...
Kyle94 Posted July 13, 2010 Author Share Posted July 13, 2010 Put a bottle under the drain on the vent system (firewall on passenger side) and see what color the fluid coming out is. If it is clear, no prob just normal condensation, green, you got a leak. You'll need to run the truck with the AC on a while to get some drainage. ill have to go try this in a lil bit. thanks guys. Link to comment Share on other sites More sharing options...
Shapes Posted July 13, 2010 Share Posted July 13, 2010 I have the same problem, except its when i have the heater on... Hmm also it sometimes smells like fuel so i donno. I think i have a small manafold leak because i can see some "wet" spots down the side of the manifold it self would that have the same smell and posibly get pulled into the cab?? Link to comment Share on other sites More sharing options...
