Kyle94 Posted May 25, 2010 Share Posted May 25, 2010 (edited) I was just wondering if there are any things that I should be looking for to give me problems... I know about the frame rust, the spot under the rear passegnger door that rusts ( like mine, anyone know how to fix it?) the transmission oils, my tach doesn't work? Any other inputs on what to be looking for over the years I'm gonna be driving it is very appriciated. Oh and I also know about the exhaust manifold studs breaking and the manifolds warping( which I'm almost sure one of those has happened on mine cuz it has an exhaust leak somewhere, and I just replaced the exhuast gaskets.... Thanks again for anyones help. Edited May 25, 2010 by kyleky07 Link to comment Share on other sites More sharing options...
Dowser Posted May 25, 2010 Share Posted May 25, 2010 New Members Area, PINNED topic Number 2. Pathfinder Common Problems/Fixes, Read this first! Amazing that the Name of the thread says everything for me... Link to comment Share on other sites More sharing options...
Kyle94 Posted May 25, 2010 Author Share Posted May 25, 2010 New Members Area, PINNED topic Number 2. Pathfinder Common Problems/Fixes, Read this first! Amazing that the Name of the thread says everything for me... yes i read this, just thought someone else might have more thoughts through personal experiances.... K? Link to comment Share on other sites More sharing options...
jbdevega Posted May 25, 2010 Share Posted May 25, 2010 im surprised there no steering report on that page. Our stock center links are absolute crap, what was Nissan thinking by using ball joints to hold that thing together. Link to comment Share on other sites More sharing options...
Precise1 Posted May 25, 2010 Share Posted May 25, 2010 About lunch?? Clean out the resistor pack behind the glove box before your truck catches on fire. Speaking of fire, if you develope an exhaust leak at the collector to mid pipe exhaust joint, it will usually burn through the floor board and set the padding and your right foot on fire. No, not much else to pay attention to, just carry marshmallows... B Link to comment Share on other sites More sharing options...
slade420 Posted May 25, 2010 Share Posted May 25, 2010 (edited) what B said ^ It even says in the owners manual not to drive barefoot. as the floor rusted out on both my D21 and pathy ive had a few problems. like the floor rusting away from the body mounts and causing the truck cab lean, having a golf ball sized hole rusted through my floor where the wiring harness for the ECU goes past the passenger's feet.. shorting out the wiring, killing the "finder of paths". Having the rear hatch "shocks" not hold the hatch up in the winter only and it falls and hits you while you're looking for something... Edited May 25, 2010 by slade420 Link to comment Share on other sites More sharing options...
Kyle94 Posted May 25, 2010 Author Share Posted May 25, 2010 About lunch?? Clean out the resistor pack behind the glove box before your truck catches on fire. Speaking of fire, if you develope an exhaust leak at the collector to mid pipe exhaust joint, it will usually burn through the floor board and set the padding and your right foot on fire. No, not much else to pay attention to, just carry marshmallows... B Resistor pack? Where would I find this and what does it look like Link to comment Share on other sites More sharing options...
Precise1 Posted May 26, 2010 Share Posted May 26, 2010 Firmly lodged in the Garage/How To section... http://www.nissanpathfinders.net/forum/index.php?showtopic=7466 Please take this in the best way possible. Take an evening and just poke around and read what is pinned and obviously displayed. It probably will not answer all of your questions, but some and it will teach you things you have not even thought of. Which means even more questions and that is what we are about here... B Link to comment Share on other sites More sharing options...
nismothunder Posted July 15, 2010 Share Posted July 15, 2010 That last post should be pinned...B's 100000000000000 times correct... Link to comment Share on other sites More sharing options...
