JB3829 Posted September 28, 2004 Share Posted September 28, 2004 Anybody ever feel a weird vibration coming from the drivetrain at 55-65 MPH (Not thru the steering wheel). '97 SE with automatic trans All four wheels have been rebalanced but it's still there! Link to comment Share on other sites More sharing options...
94extreme Posted September 28, 2004 Share Posted September 28, 2004 does your tk make a clunking noise when you shift the tranny from r-n-d? or the other way... Link to comment Share on other sites More sharing options...
lewisnc100 Posted September 28, 2004 Share Posted September 28, 2004 All four wheels have been rebalanced but it's still there! Did the balance use a flange plate adapter to mount the wheels to the balancer, without it your wheels really aren't balanced. If you had the balance done at the dealer they should have used the adapter. Link to comment Share on other sites More sharing options...
JB3829 Posted September 29, 2004 Author Share Posted September 29, 2004 No clunking noises and I don't think the local tire shop used a flange plate adapter...I'm wondering if it has something to do with a driveshaft. The vibration shows up with overdrive on or off. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 29, 2004 Share Posted September 29, 2004 Check your rear axle trailing arm/control arm bushings. Sounds like they may be going on you. Link to comment Share on other sites More sharing options...
jaafallon Posted September 29, 2004 Share Posted September 29, 2004 In my experience vibrations that occur between 55 and 65 are almost always a rear-wheels balancing problem. I'd take it back to where they were balanced, explain the problem, and ask them to check the balance again. I've never had a shop deny that service and it has almost always corrected the problem. Let us know. jim Link to comment Share on other sites More sharing options...
lewisnc100 Posted September 30, 2004 Share Posted September 30, 2004 I'd take it back to where they were balanced, explain the problem, and ask them to check the balance again. Good advice, but without using the flange plate adapter on the 97 SE wheels as described in TSB 98-102, getting a good balance on those wheels will be pure luck. Definitely ask if they have a flange plate adapter and mention that it is required for your wheels, maybe they'll pick up the tab for a Nissan dealer balance since they should have the right adapter. If they don't know what you are talking about show them this pic: http://groups.msn.com/LewisPictures/shoebo...hoto&PhotoID=10 This allows the wheel to be centered on the balance machine via the lugs vs. the hub hole. Link to comment Share on other sites More sharing options...
