headpeace Posted March 14, 2010 Share Posted March 14, 2010 after some research I've found the 05's had issues with radiator fluid leaking into the tranny cooler and ruining the tranny. You guys know of any drawbacks to bypassing the OE tranny cooler and going straight to an external cooler? I really can't afford a new tranny in this thing Link to comment Share on other sites More sharing options...
morpheus Posted March 14, 2010 Share Posted March 14, 2010 (edited) I tell everyone I can to bypass the factory radiator cooler and put a stand alone cooler on an 05+ pathfinder/xterra/frontier. They all blow eventually, just a ticking timebomb. Just make sure you get the correct size cooler for your application.. This case, too big isn't better, it can make the fluid too cold. The only thing you might notice, is a bit of a funny shift, or a lack of lockup at highway speeds when starting off with the vehicle cold (sat overnight) because the radiator also warms the fluid up to operating temperature quicker. That won't hurt it, just will take longer for the fluid to warm up. Edited March 14, 2010 by morpheus Link to comment Share on other sites More sharing options...
headpeace Posted March 14, 2010 Author Share Posted March 14, 2010 (edited) what size do you recommend?? I don't tow anything and don't plan to as of now Edited March 14, 2010 by headpeace Link to comment Share on other sites More sharing options...
morpheus Posted March 14, 2010 Share Posted March 14, 2010 I don't have any personal experience with using them, but from what I've seen they are based on engine size and horsepower. Someone on here might be able to offer better advise. Link to comment Share on other sites More sharing options...
headpeace Posted March 14, 2010 Author Share Posted March 14, 2010 I am looking at the Hayden 405, would the 404 be better? Link to comment Share on other sites More sharing options...
Alkorahil Posted March 20, 2010 Share Posted March 20, 2010 I like the old B&M coolers (or similar style) as opposed to the hayden (or similar style) you mentioned. The B&M have stacked steel flutes around the aluminium to protect it from rocks, etc. Link to comment Share on other sites More sharing options...
dryart Posted May 13, 2010 Share Posted May 13, 2010 I tell everyone I can to bypass the factory radiator cooler and put a stand alone cooler on an 05+ pathfinder/xterra/frontier. Just make sure you get the correct size cooler for your application.. This case, too big isn't better, it can make the fluid too cold. 2005+ Pathfinders already have a "stand alone" transmission oil cooler. Some people are adding a thermostatically controlled fan to it, especially for heavy load and towing applications. Link to comment Share on other sites More sharing options...
jerry6 Posted July 5, 2010 Share Posted July 5, 2010 2005+ Pathfinders already have a "stand alone" transmission oil cooler. Some people are adding a thermostatically controlled fan to it, especially for heavy load and towing applications. So is it enough to block the coolant rad section off and run the factory trans cooler alone , or is a suplimental cooler needed ? Link to comment Share on other sites More sharing options...
headpeace Posted July 5, 2010 Author Share Posted July 5, 2010 I've had mine bypassed since March, using the factory cooler only and the fluid is still nice and red, but it certainly wouldn't hurt to add an extra. I plan to add a temp gauge at some point and then determine if I need an extra cooler. If you tow anything I would say definitely add another cooler Link to comment Share on other sites More sharing options...
jerry6 Posted July 5, 2010 Share Posted July 5, 2010 Thanks , guess I'll block off the rad and add an extra cooler with a temp gauge , better safe than in the repair shop dropping mega$$$ . And I sure don't want to hear how this is NOT covered under the super extended warranty . Any idea on a good cooler , B&M or is there something better ? Link to comment Share on other sites More sharing options...
morpheus Posted July 6, 2010 Share Posted July 6, 2010 I cant' offer any advice on if an add on cooler is enough or not, as I have no experience with them.. all I can stress is don't leave the radiator cooler connected, you might regret it. Link to comment Share on other sites More sharing options...
jerry6 Posted July 6, 2010 Share Posted July 6, 2010 I cant' offer any advice on if an add on cooler is enough or not, as I have no experience with them.. all I can stress is don't leave the radiator cooler connected, you might regret it. No plans for regret , will visit my buddies transmission shop Wednesday and have the rad blocked and aux cooler installed , with temp gauge Link to comment Share on other sites More sharing options...
abomb1 Posted July 11, 2010 Share Posted July 11, 2010 I bypassed my radiator and am just using the stock transmission cooler on mine. It was very easy to bypass and cost less than $10 in supplies at the auto parts store. Link to comment Share on other sites More sharing options...
