mickyficky Posted January 25, 2010 Share Posted January 25, 2010 My ABS and Brake lights (1995 with 175K) have been coming on and off for about a week. It seems random. Does anyone know what this is a warning for? I don't have an owners manual, can someone check for me? Also, I have searched the forum and found that battery + brake = bad alternator. Thanks Link to comment Share on other sites More sharing options...
nige Posted January 25, 2010 Share Posted January 25, 2010 check your brake fluid level Link to comment Share on other sites More sharing options...
Simon Posted January 25, 2010 Share Posted January 25, 2010 X2 on the fluid. Link to comment Share on other sites More sharing options...
Precise1 Posted January 25, 2010 Share Posted January 25, 2010 x3 You may have to gravity bleed the ABS unit to get that light to go away. Also, unless you have a leak, it probably means your brake pads are getting worn. If you top off the fluid, when you change the brake pads and push the piston back into the caliper, it may overflow. Easy to circumvent, but be aware. B Link to comment Share on other sites More sharing options...
mickyficky Posted January 25, 2010 Author Share Posted January 25, 2010 Thanks everyone . All of this sounds right because I know my pads are in desperate need of replacement. I will check the brake fluid, change the pads, top off the fluid if necessary and then post the outcome of the indicator lights. Link to comment Share on other sites More sharing options...
edicer2 Posted January 25, 2010 Share Posted January 25, 2010 x4 check the pads, brake fluid, and make sure a caliper isnt hanging up anywhere. Link to comment Share on other sites More sharing options...
