Dash Lights In 88 Pathfinder
ant
its your fuses i bet check them out in the panel by your feet. only other thing i could trhink of is the light switch has a bad connection but check the fuses.
x2
turn up the brightness?
As dumb as it sounds x1000 easily bumped and not known
thanks for all the suggestions i checked the fuses they are all good... turned up the brightness and still nothing.. i will check out that ground
By dashboard lights do you mean...
Instrument cluster illumination lights?
Dash related illumination lights (this includes heater controls)
All lights, including warning lights in the instrument cluster?
Did they work then suddenly stop, or has portions of the display gone out over time?
Have to pulled the cluster and/or heater controls to check the bulbs?
All but one of my cluster illumination lights has been out for a long time now, but recently my clocks back light died. So I pulled the cluster last night to change bulbs and see what, if anything else may be causing it.
Only one bulb was bad, but several of the light sockets were loose (including the recently dead clock back light). Problem was they were loose because the housing of the cluster is falling apart. It's old and brittle and the "locks" that the sockets turn onto have fallen to pieces, some literally dust.
I temporarily fixed it, but it's just a matter of time before they go out again.
A new cluster housing is in my future.
