frecklecolouredbrain Posted December 23, 2009 Share Posted December 23, 2009 Should i be able to hear my transfer case chain? its really quiet, but I can hear it. Like I said, i just got by hearing back for the first time since before i bought the truck. Link to comment Share on other sites More sharing options...
nismothunder Posted December 23, 2009 Share Posted December 23, 2009 What ja say!!!... Are you in four wheel drive? if so then I wouldnt be afraid of a little noise since there usally a little louder in four wheel drive.Could it be you CVs...is it like a clicking... Link to comment Share on other sites More sharing options...
Precise1 Posted December 23, 2009 Share Posted December 23, 2009 It's not unusual to hear assorted drive train noise to a small degree, but once you can easily identify the noise, I'd say take a look. Get the replacement lubricant (I think yours states gear oil), remove the filler plug and then the drain plug. What is the fluid like? How much crap on the drain magnet? How big are the pieces? Unless you have a lot to share about the above, replace the drain plug, fill it, seal it and drive it... B Link to comment Share on other sites More sharing options...
frecklecolouredbrain Posted December 23, 2009 Author Share Posted December 23, 2009 it definately the t-case. i can hear the chain doin it's chain thing. just need to know if its normal to hear. fluids good, runs good, no crap on the plug at all. yes it clicks, but it's not a CV-type clicking as far as i can tell, and i don't feel it through the wheel. it started a little last winter, but only in reverse only on the outer wheel when turning. now its forward and reverse, outer wheel only when the wheels are past half way to max turn. could that be an Auto-Hub thing? Link to comment Share on other sites More sharing options...
Precise1 Posted December 23, 2009 Share Posted December 23, 2009 Sounds like you are ok with the T case chain, just drive it. If you hear the noise change significantly, that may indicate a problem. Is the clicking once per rev, 2x per rev, etc?? Nothing else should be making that noise. B Link to comment Share on other sites More sharing options...
Terrano1992 Posted December 23, 2009 Share Posted December 23, 2009 (edited) it started a little last winter, but only in reverse only on the outer wheel when turning. now its forward and reverse, outer wheel only when the wheels are past half way to max turn. could that be an Auto-Hub thing? Yes. Check your "A/B brake" pair height, as described in FSM. Replace if they are worn. Also, fill transfer case with Dexron-III or any other equivalent ATF, not a gear oil. Dexron has a less cold viscosity than 75W-90 GL-4/5. It's a Nissan recommended thing. Edited December 23, 2009 by Terrano1992 Link to comment Share on other sites More sharing options...
nismothunder Posted December 23, 2009 Share Posted December 23, 2009 The clicking in reverse makes me sustect its the transmission not shifting into gear all the way... Link to comment Share on other sites More sharing options...
frecklecolouredbrain Posted December 23, 2009 Author Share Posted December 23, 2009 thanks for the ATF tip terrano. I don't know why, but something tels me i should trust you on the cold weather tips. Link to comment Share on other sites More sharing options...
Terrano1992 Posted December 25, 2009 Share Posted December 25, 2009 (edited) thanks for the ATF tip I can explain more, this is not a misterious thing. Thick (high viscosity) gear oil causes slow irregular rotation of front propeller shaft when "2H" selected in transfer case (thick liquid acts as a viscous clutch). As a result, you can hear repeated clicks or whirring at front axle, produced by spontaneously engaged (and immediately disengaged, because you have no real torque on driveshaft) automatic hubs, until transfer case oil warms to working temperature. Dexron-III or higher spec ATF really helps to cure this problem. At least, up to -25..-30 deg.C. Edited December 25, 2009 by Terrano1992 Link to comment Share on other sites More sharing options...
