DVO Posted December 19, 2009 Share Posted December 19, 2009 I been searching for a VERY long time.. And found NOTHING to no avail... My 90 SE has them goofy pods for the speakers... How the heck do I get into them? I'm not sure if it's the wiring thru the amp for them or if they're just wired gimpy... I had some good ones put in a couplea years ago, not knowing I had rear ones already, to find that the stock ones were good, just not working for some reason... Well... In the last year, my rear speakers have dropped off totally... If it's not to do with the stock amp, anyone know how to get them things off so I can re-wire the whole thing? I have a rather large 2x12 Alpine box in there now with JBL's and a 1300w Class D... That with the stock door speakers? Well... Yea... I need them 67x9's to work... Link to comment Share on other sites More sharing options...
Steve_RI Posted December 21, 2009 Share Posted December 21, 2009 The speaker grill needs to come off. Just pry it up gently. I ended up pulling these things out of my truck to free up some room. Link to comment Share on other sites More sharing options...
edicer2 Posted December 21, 2009 Share Posted December 21, 2009 the grill pops off just look to where the two peices of plastic sperate and try and pop them off. I have done it with my hand before so its not to hard to pop apart. Link to comment Share on other sites More sharing options...
DVO Posted December 21, 2009 Author Share Posted December 21, 2009 Thanks for the replies, guys... Nice to know that when Google fails, SOMEONE will know... Link to comment Share on other sites More sharing options...
PATHRIDER Posted February 18, 2010 Share Posted February 18, 2010 This site is better than google Link to comment Share on other sites More sharing options...
Precise1 Posted February 18, 2010 Share Posted February 18, 2010 LOL For pathfinders anyway... Yeah, I just fully removed a set in a junk yard including all required trim. It all snaps/clips together or has clearly accessable phillip head screws. B Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted February 21, 2010 Share Posted February 21, 2010 If you want to remove the whole pod, then you'll have to pop off the top "screened" part, then pry off the plastic that surrounds the 'pod'. If I remember correctly each pod has two pieces? Been over a year since I tinkered with mine, and I don't have my rig nearby. Once you do that, there will be four screws that you can remove, and pull the pod off the side panel. There's a white connection behind that pod, if you decide to put your good speakers in there and they are amped, I would suggest bypassing that plug. Link to comment Share on other sites More sharing options...
