ChrisPerna Posted December 8, 2009 Share Posted December 8, 2009 So i have an awefull ticking sound and i think i need to replace the lifters, the only problem is that i dont know how to. has anyone sone it before. i have searched and found nothing Link to comment Share on other sites More sharing options...
TerranoNZ Posted December 8, 2009 Share Posted December 8, 2009 Easy enough done, though being a MPFI you will need to remove the intake manifold to get to the left head. If you don't really know what your in for, buy a manual or find the FSM that is floating around here...Somewhere. When you get the covers off you'll see this Just undo the 6/12mm head bolts (EVENLY) and remove the rockers and shafts, then the lifter housing comes right off. I'd still bet money on rocker shafts, but hey. Good luck. BTW other than basic tools you will need a torque wrench that goes as low as 18-22nm Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 8, 2009 Author Share Posted December 8, 2009 well can i do this in my drveway, also how ling does it take and what do i need to buy? Link to comment Share on other sites More sharing options...
MY1PATH Posted December 8, 2009 Share Posted December 8, 2009 get your lifters from abcnissan.com they have the best price. and be sure so soak the lifters in oil and aggitate them while soaking before you install them. this will reduce premature wear and make them stay quiet longer. Link to comment Share on other sites More sharing options...
Precise1 Posted December 8, 2009 Share Posted December 8, 2009 Better price than from Alkorahil?? B Link to comment Share on other sites More sharing options...
MY1PATH Posted December 9, 2009 Share Posted December 9, 2009 last I checked they were $10ea with my N4W dicount, but u can always ask Alkorahil to hook u up too. Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 9, 2009 Author Share Posted December 9, 2009 so what exactallly do i need to do this job complete so i can order the parts Link to comment Share on other sites More sharing options...
MY1PATH Posted December 9, 2009 Share Posted December 9, 2009 (edited) 12 lifters 2 Gaskets for valve covers intake manifold gasket throttle body gasket oil 5w30 coolant philips screwdriver metric socket set torque wrench Edited December 9, 2009 by MY1PATH Link to comment Share on other sites More sharing options...
MY1PATH Posted December 9, 2009 Share Posted December 9, 2009 and to point you in the right direction... put your lifters in a bucket with oil, suffle them arround everey step to get the air bubles out so the oil soaks better. drain about 1 gallon or more from your radiator, this will make things less messy when you take of your manifold. unbolt thottle body and coolant hoses from manifold let it hang to the side, begin removing manifold once manifold is off remove valve covers starting @ each end alternat lostening each bolt on the rocker shaft (1/2 turn only) when you get to the center do a 1/2 turn on the ones you didn't get. repeat the process doing full turns this time. Keep repeating but don't do more than a full turn utill there is no load on the rocker shaft from the valve springs. finish removing rocker shaft. remove lifter galley and replace lifters(remember you shook'em in the bucket every step). If the flat of any lifter looks exessively or oddly worn by the cam you may want to consider a new cam or haing the old one re-condidtioned. install lifter galley and rocker shaft slowly following the same sequence as above. (don't forget to use torqe wrench to spec) replace valve cover gasket if neede and then valve cover. replace everyting else and top off your coolant. that may not be everyting but it will get you in the right direction. Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 9, 2009 Author Share Posted December 9, 2009 (edited) what about the rockers and shafts how do i do them? i dont want any more ticking so i wanna do everything i need to do lol Edited December 9, 2009 by ChrisPerna Link to comment Share on other sites More sharing options...
bitemedoughboy.com Posted December 9, 2009 Share Posted December 9, 2009 Easy enough done, though being a MPFI you will need to remove the intake manifold to get to the left head. If you don't really know what your in for, buy a manual or find the FSM that is floating around here...Somewhere. When you get the covers off you'll see this Just undo the 6/12mm head bolts (EVENLY) and remove the rockers and shafts, then the lifter housing comes right off. I'd still bet money on rocker shafts, but hey. Good luck. BTW other than basic tools you will need a torque wrench that goes as low as 18-22nm thats some nasty sludge, time for sea foam? or a different oil Link to comment Share on other sites More sharing options...
MY1PATH Posted December 9, 2009 Share Posted December 9, 2009 what about the rockers and shafts how do i do them? i dont want any more ticking so i wanna do everything i need to do lol if you wanna change the rockers and safts buy some new ones(if you can) and they are pretty self explanitory. I think its just the lifters that tick, when they wear out they don't hold on to oil as well so after the vehicle has been sitting they drain out and tick is the sound of a hydraulic lifter collapsing becasues its empty. Link to comment Share on other sites More sharing options...
Dowser Posted December 10, 2009 Share Posted December 10, 2009 Here's someones write up as well which basically shows step by step what needs to happen. Good luck. and Search could have found this. Lifter Swap. Link to comment Share on other sites More sharing options...
TerranoNZ Posted December 10, 2009 Share Posted December 10, 2009 thats some nasty sludge, time for sea foam? or a different oil That was nothing Have a look at the head on my 93's old engine Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 10, 2009 Author Share Posted December 10, 2009 so i really wanna get this done but im a little worried about it, like how tough is it gettin the lifters out and what can i fskc up doing it? Link to comment Share on other sites More sharing options...
TerranoNZ Posted December 10, 2009 Share Posted December 10, 2009 Hard to answer as it's all relative To me and quite a few others it's a piece of cake, but I bet to some it looks daunting. Do you know someone mechanically minded to help you? Link to comment Share on other sites More sharing options...
Precise1 Posted December 10, 2009 Share Posted December 10, 2009 That was nothing Have a look at the head on my 93's old engine That is a really nasty picture, Tex. I wish you wouldn't be so eager to flash it all the time... so i really wanna get this done but im a little worried about it, like how tough is it gettin the lifters out and what can i fskc up doing it? Did you read the link that was provided for you?? B Link to comment Share on other sites More sharing options...
MikeV Posted December 10, 2009 Share Posted December 10, 2009 You sure it's lifters and not the exhaust manifold? Link to comment Share on other sites More sharing options...
Chriskaw440 Posted December 12, 2009 Share Posted December 12, 2009 That is a really nasty picture, Tex. I wish you wouldn't be so eager to flash it all the time... Thats craziness in that picture...a good example of: never changing the oil, using WAL MART brand oil LOL, or using every chemical gimmick (snake oil) product one can find on any store shelf. (or the oil paths were so blocked that oil could never circulate properly.) Any engine with tons of miles on it will have SOME build up in it, and just because there is a little on the rockers or thereabouts is not a red flag to immdeiately do an engine flush. You can't keep a well used engine as clean as when it was new....unless you want to spend big bucks by having it done professionally and using full synthetic oil. Using chemicals to flush and clean excessively can actually cause damage by eating away the seals. Link to comment Share on other sites More sharing options...
ChrisPerna Posted January 22, 2010 Author Share Posted January 22, 2010 so i ordered 12 lifters and 6 rocker arms. what else should i get? Link to comment Share on other sites More sharing options...
andreus009 Posted January 22, 2010 Share Posted January 22, 2010 (edited) You sure it's lifters and not the exhaust manifold? I have to second this question. The tick caused by broken exhaust manifold studs can sound similar to a bad lifter tick. Hate to see you tear into the lifters and not solve your problem. BTW, in case you haven't read it yet. The broken exhaust manifold stud issue is common issue to the vehicles thru 95. How long does the ticking sound last? If you turn it off and immediately restart does it quit? (I have a lifter tick at start up but usually goes away quickly. Sometimes it will hang in there for a little longer, so I'll shut down and then restart which has so far always stopped the tick) so i ordered 12 lifters and 6 rocker arms. what else should i get? Umm...to ask the obvious....did you get the gaskets too? Also, have magnetic pickup wand handy. I dropped a lifter down in the head when I did a car I had. Thankfully, I was able to recover it with a magnetic tipped wand. Hope it doesn't happen to you. Edited January 22, 2010 by andreus009 Link to comment Share on other sites More sharing options...
ChrisPerna Posted January 22, 2010 Author Share Posted January 22, 2010 I have to second this question. The tick caused by broken exhaust manifold studs can sound similar to a bad lifter tick. Hate to see you tear into the lifters and not solve your problem. BTW, in case you haven't read it yet. The broken exhaust manifold stud issue is common issue to the vehicles thru 95. How long does the ticking sound last? If you turn it off and immediately restart does it quit? (I have a lifter tick at start up but usually goes away quickly. Sometimes it will hang in there for a little longer, so I'll shut down and then restart which has so far always stopped the tick) Umm...to ask the obvious....did you get the gaskets too? Also, have magnetic pickup wand handy. I dropped a lifter down in the head when I did a car I had. Thankfully, I was able to recover it with a magnetic tipped wand. Hope it doesn't happen to you. alright my problem is that when i start the truck theres no tick then once it warms up it will start ticking. any ideas? Link to comment Share on other sites More sharing options...
andreus009 Posted January 23, 2010 Share Posted January 23, 2010 alright my problem is that when i start the truck theres no tick then once it warms up it will start ticking. any ideas? Well, haven't heard of one behaving that way specifically. However, on top of the exhaust manifold stud issue I have read of some people having found the exhaust manifold itself cracked. I could imagine that with a cracked manifold it might be quieter at the start and get more loud as it got warm (i.e. crack opens with temperature) Personally, I'd probe around the exhaust manifolds first to see if a) there were broken studs and/or if there were any cracks in the manifolds. When checking the studs try grabbing the ends with some pliers and pull a little bit. Sometimes the studs will crack, but stay in place so you won't know if they are broken unless you pull on them. Sorry, I do not specifically know if lifters can start out quiet but then start ticking after the engine warms up. Anyone? Link to comment Share on other sites More sharing options...
beastpath Posted January 23, 2010 Share Posted January 23, 2010 so i ordered 12 lifters and 6 rocker arms. what else should i get? you should only need 4 rocker arms. Link to comment Share on other sites More sharing options...
TerranoNZ Posted January 23, 2010 Share Posted January 23, 2010 you should only need 4 rocker arms. How so? Link to comment Share on other sites More sharing options...
