ChrisPerna Posted December 4, 2009 Share Posted December 4, 2009 so i plan on doing a complete tune-up on my truck since it gets 10 mpg, what should i get for this job? Link to comment Share on other sites More sharing options...
MY1PATH Posted December 4, 2009 Share Posted December 4, 2009 (edited) Did you check the ecu for codes? 10mpg may be more than just outa tune. any draging brakes or diff fluids that have never been changed. (the oil shears down and becomes thick with wear particles) Plugs, wires, cap and rotor. (go ngk for the first 2 and Neighoff, bosh or Nissan for the other 2) o2 sensor (bosh or NGK/ntk) clean your MAF (gently) check your timing belt; tentsion & position Fuel filter Air filter check cat for cloging, crumbling or melting. seafoam Timing; 15 btdc @ 600-750 rpm with no accesories running. more... Edited December 4, 2009 by MY1PATH Link to comment Share on other sites More sharing options...
Precise1 Posted December 4, 2009 Share Posted December 4, 2009 10mpg says there is a problem. Check cap and rotor, I have had the center electrode disappear (and still run!!) O2 sensor exhaust leak fuel leak Wasn't all this gone over already? B Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 5, 2009 Author Share Posted December 5, 2009 i do have an exhaust leak, and im not throwing any lights, i just wanna know whats wrong with the thing Link to comment Share on other sites More sharing options...
Precise1 Posted December 5, 2009 Share Posted December 5, 2009 Fair enough... If the exhaust leak is before the O2 sensor, you need to take care of it first. B Link to comment Share on other sites More sharing options...
ac92pathfinder Posted December 5, 2009 Share Posted December 5, 2009 im getting around 180 on a full tank. but thats probably from my route job with all the stop and go. Link to comment Share on other sites More sharing options...
Alkorahil Posted December 5, 2009 Share Posted December 5, 2009 Commonly missed parts on older vehicles include: Vaccum booster check valve PCV valve Idler pully Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 6, 2009 Author Share Posted December 6, 2009 Commonly missed parts on older vehicles include: Vaccum booster check valve PCV valve Idler pully whats the vaccum booster check valve Link to comment Share on other sites More sharing options...
Alkorahil Posted December 7, 2009 Share Posted December 7, 2009 A vacuum booster uses vacuum pressure from the engine to boost the amount of pressure going to the brakes. The check valve on vacuum booster regulates the amount of pressure in the booster. If the valve is malfunctioning or clogged, the booster will produce an insufficient amount of pressure to the brakes. It is located on the rubber hose mounted to teh firewall going from the brake booster to the engine. Link to comment Share on other sites More sharing options...
ChrisPerna Posted December 7, 2009 Author Share Posted December 7, 2009 A vacuum booster uses vacuum pressure from the engine to boost the amount of pressure going to the brakes. The check valve on vacuum booster regulates the amount of pressure in the booster. If the valve is malfunctioning or clogged, the booster will produce an insufficient amount of pressure to the brakes. It is located on the rubber hose mounted to teh firewall going from the brake booster to the engine. thank you, so is a tune up gonna run me about 200? Link to comment Share on other sites More sharing options...
