Joho Posted October 20, 2009 Share Posted October 20, 2009 Hello all, I have a 1999.5 R50. I own the owner's manual and the Haynes and I have not been able to locate any jack stand points; I know the stock jack points. The Haynes mentions placing jack stands on the "frame" when doing tire rotation--where exactly is this, and can I do it with only two jack stands or does this require all four? I am looking to jack up the front to do some maintenance (getting tired of sliding under my car at stock ride height). Thanks in advance! Joho Link to comment Share on other sites More sharing options...
Pezzy Posted October 20, 2009 Share Posted October 20, 2009 We've used the jack stands on the subframe crossmember on the front... or the lower control arms. I don't see why you need 4... unless they are suggesting you have all 4 wheels off the ground at once!?!?! Link to comment Share on other sites More sharing options...
Joho Posted October 20, 2009 Author Share Posted October 20, 2009 We've used the jack stands on the subframe crossmember on the front... or the lower control arms. I don't see why you need 4... unless they are suggesting you have all 4 wheels off the ground at once!?!?! Is there any chance you could provide a picture or diagram of some sort? I'm a bit confused as to where exactly to place the stands and I want to be careful. Link to comment Share on other sites More sharing options...
GrimGreg Posted October 21, 2009 Share Posted October 21, 2009 Just stick em under the frame.....wait.....uh Link to comment Share on other sites More sharing options...
fleurys Posted October 21, 2009 Share Posted October 21, 2009 here you go. Link to comment Share on other sites More sharing options...
GoPathyGo Posted October 22, 2009 Share Posted October 22, 2009 The jack points should look like little upside-down saucers on the frame rails. I usually put the head of the jack as close to the center of the saucer as I can. Link to comment Share on other sites More sharing options...
Darek Posted May 11, 2013 Share Posted May 11, 2013 Hi guys. I am going to rotate tires today. I have a stock jack and two safety stands. Can I lift it with stock jack placed under center front and center rear garage jack points as on picture above? Won't the vehicle incline on side? Link to comment Share on other sites More sharing options...
Bluewulf73 Posted May 13, 2013 Share Posted May 13, 2013 Probably safest to lift one side at a time. OEM jack is too narrow and yes, you risk ahving the truck tip to one side. Link to comment Share on other sites More sharing options...
DIRT_LIFE Posted October 22, 2017 Share Posted October 22, 2017 You guys are life savers. Thanks for sharing. ....I would do some serious damage to my ride if weren't for this forum Link to comment Share on other sites More sharing options...
