ac92pathfinder Posted July 17, 2009 Share Posted July 17, 2009 im looking for a after market temp gauge for my 92 pathfinder i got one from autozone i forgot what brand it is starts with an s but anyway the fittings are too big to put where the temp sensor goes. i was wondering if anyone can tell what after market gauges will fit on there or maybe i can hook it somewhere else. thanks Link to comment Share on other sites More sharing options...
Kingman Posted July 17, 2009 Share Posted July 17, 2009 You can just spice a new thermostat into a coolant line and run the wires along your fender well and into the firewall to the temperature gauge that would be mounted wherever you would want it to go. Link to comment Share on other sites More sharing options...
MY1PATH Posted July 18, 2009 Share Posted July 18, 2009 x2 greddy makes on that you can slipinto your coolant line under your radiator hose, the flexibiltiy of the hose seals the wire and then you can run it to wherever. Link to comment Share on other sites More sharing options...
headpeace Posted July 18, 2009 Share Posted July 18, 2009 you could try Napa and see if they have a fitting that would work Link to comment Share on other sites More sharing options...
CSIPSD Posted July 18, 2009 Share Posted July 18, 2009 im looking for a after market temp gauge for my 92 pathfinder i got one from autozone i forgot what brand it is starts with an s but anyway the fittings are too big to put where the temp sensor goes. i was wondering if anyone can tell what after market gauges will fit on there or maybe i can hook it somewhere else. thanks Check out Isspro, they make gauges for everything, I run 17 of them in my powerstroke! Link to comment Share on other sites More sharing options...
beastpath Posted July 18, 2009 Share Posted July 18, 2009 greddy prices are about $200! thats a lot for a guage IMO. if you disconnected the OEM guage sensor wire from the sender could you connect an aftermarket one to it? or does it read differently? Link to comment Share on other sites More sharing options...
