exit34rocker1017 Posted July 8, 2009 Share Posted July 8, 2009 after my AC lift, im getting new wheels and 32x10.5 BFG AT's, or dick cepek radial FCII's. question is, what size wheel do i get? i know i get 16, but width? backspacing? im thinkin 16x8 with 3.75 backspacing. if i like the wider stance look, would it make sense to get 16x8 with 2.5 backspacing? thats the next lowest BS that i can find in the rock crawlers. please help me ive been reading these forums for months now and still dont know what to do! Link to comment Share on other sites More sharing options...
94extreme Posted July 8, 2009 Share Posted July 8, 2009 nah, go with 22s. Link to comment Share on other sites More sharing options...
Nissan3 Posted July 8, 2009 Share Posted July 8, 2009 after my AC lift, im getting new wheels and 32x10.5 BFG AT's, or dick cepek radial FCII's. question is, what size wheel do i get? i know i get 16, but width? backspacing? im thinkin 16x8 with 3.75 backspacing. if i like the wider stance look, would it make sense to get 16x8 with 2.5 backspacing? thats the next lowest BS that i can find in the rock crawlers. please help me ive been reading these forums for months now and still dont know what to do! Really its your preference what ever you feel looks cool. Personally I dont like too much backspacing right now I got 4.5"bs on a 9 inch rim and am very happy with the stance now, before i had 4"bs on 8" rim and thought the wheels stuck out a little too much. Thats weird though I've never heard of a wheel having less then 3.5" backspacing. anyway good luck with the search. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted July 8, 2009 Share Posted July 8, 2009 2.5" BS and your wheels are gonna stick out quite a lot. If that's the look you're wanting, go for it. 3.75" BS seems to be pretty much the norm. That's what I have, and they stick out about an inch or so past the lip. I've got the OEM flares and my tires sit pretty much flush with the edge of the flare. Let us know what you decide on doing, and by all means post pics! Link to comment Share on other sites More sharing options...
FUELER Posted July 8, 2009 Share Posted July 8, 2009 3.75 should be the farthest OUT you should go and 4.5 should be the farthest IN you should go anything inbetween will work.... Link to comment Share on other sites More sharing options...
GoPathyGo Posted July 9, 2009 Share Posted July 9, 2009 (edited) FYI, I searched a lot for wheels with low backspacing. I don't like rubbing at all and I didn't want to use spacers. The only wheels I could find that came with 3.5" or less of backspacing were Mickey Thompson Aluminum wheels that cost $130 each, if I remember correctly. I didn't want aluminum because I wheel regularly and the aluminum wheels would get hammered. Eventually, I found you can order steel wheels with custom backspacing from US Wheel or Cragar via Summit Racing. The lowest US Wheel would go is 3.125" backspacing. I took 3.125" and compensated a bit by getting a smaller width. Went with 16x7 instead of 16x8. That saved me $20 ($70 for the 16x7 vs $90 for the 16x8) and some weight. I think they said they could go lower than 3.125" but then you'd be looking at a reverse wheel. Reverse wheels can sometimes cause problems with the rest of your setup (brakes etc). I am trying different shades of Rust-Oleum right now to see if I can get a nice shiny look. On my truck, the 3.125" backspacing on a 16x7 wheel means my wheels only stick out about 1" to 1.5" rom the fender flares. May be less. I like the look but as others have pointed out, that's a personal preference. Edited July 9, 2009 by GoPathyGo Link to comment Share on other sites More sharing options...
FUELER Posted July 9, 2009 Share Posted July 9, 2009 my stock wheels were 16x7 Link to comment Share on other sites More sharing options...
exit34rocker1017 Posted July 9, 2009 Author Share Posted July 9, 2009 i like the wheels sticking out a little, and an inch or two sounds good, so i think ill go with the wheels with 3.75 backspacing, and hope getting 32's will not cause rubbing! -thanks guys rob Link to comment Share on other sites More sharing options...
180sx Posted July 9, 2009 Share Posted July 9, 2009 I got a set of 15x10's with 3.75" back spacing waitng on some tires to be mounted (32x11.50's). When i put the bare rim on, they stuck out past the flare about half an inch. Can't imagine what it'll be like when the tires are on there. Hopefully and can scrounge up some coins to get a SFD made so i can throw some 33's on these bad boys! Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted July 9, 2009 Share Posted July 9, 2009 I got a set of 15x10's with 3.75" back spacing waitng on some tires to be mounted (32x11.50's). When i put the bare rim on, they stuck out past the flare about half an inch. Can't imagine what it'll be like when the tires are on there. Hopefully and can scrounge up some coins to get a SFD made so i can throw some 33's on these bad boys! Sweet!! I'm planning on installing 33x12.5 tires when the SFD kit gets here, and mount them on a 15x10 wheel with 4" BS. Link to comment Share on other sites More sharing options...
180sx Posted July 10, 2009 Share Posted July 10, 2009 Took some quick snaps of the wheels I plan on putting on the pathy. They are not new, they came off my buddies Taco before he SAS'd it. They are 15x10 with 16mm offset (between 3.75" and 4" of BS) This is it on the pathy: Side View of it: Clearance when turned to the right. Can we say trimming of bumper and fender?: Clearance when turned to the left. More trimming needed! Imagine with a 32" tire on there! And how wide it is compared to my 31x10.5 tire on the stock 15x7 wheel: sorry to thread jack!! Jose Link to comment Share on other sites More sharing options...
exit34rocker1017 Posted July 11, 2009 Author Share Posted July 11, 2009 looks sweet jose! i love the wideness. my friend just put 32's on his yukon, with 16x8 rims with 4.5 backspacing. luckily he's got the same bolt pattern as pathfinders, so when i get my lift he said he'll let me test out the 32's, see if theres rubbing, and see if i want more or less backspacing when i get my own rims. works out great Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted July 11, 2009 Share Posted July 11, 2009 Agreed! Those 15x10 wheels look nasty! With some nice MTs you'll have a nice beefy stance. Even with ATs it'll look just killer. Mmmm, now I want. Link to comment Share on other sites More sharing options...
180sx Posted July 13, 2009 Share Posted July 13, 2009 Thanks. I would like to get Good Year A/T's on them, since they are not too high in price and last longer then the BFG's do. We'll see. I'm just wondering how much trimming is gonna have to be done to fit these. Link to comment Share on other sites More sharing options...
