Long Travel Shocks
unccpathfinder
So I need to get some long travel shocks for the 87 now that I have the lift on...just curious if there are some WD specific LTS or what do most people run to get more flex out of the rear (dont think the front matters too much). If there is another thread with the info i missed it and if someone would kindly post it i'd appreciate it.
I'm thinking I may need to fab up some coil spring retainers as well
I used rancho 9x's the model was the 9112 which is 3" inches longer than stock. I have read on other threads that JGC's & Fords will get loose @ full drop.
If your are running AC coils you may be ok w/o the retainer. I think the calmini coils may be shorter than the ac's but I don't know if they fall into the loose category for the 9112's
(If you wanna stay with the 5x's its the 5112's)
here's the info I gathered once I decided to go-rancho;
9112's are 26" extended 3" over stock may limit full compression by about 2"
9116's are 24" extended 1" over stock & used in most lifted aplications
9118 & oem 23" extended
