Spenceeros Posted May 22, 2009 Share Posted May 22, 2009 I have a 92 pathfinder with 213,000 miles and was wondering, is it necessary to flush out the old power steering fluid once in a while? The second part is how hard is it to flush? I've read forums that say all you have to do is disconnect the reservoir and run your engine. This doesn't sound like a good idea. Link to comment Share on other sites More sharing options...
adamzan Posted May 22, 2009 Share Posted May 22, 2009 If the fluid looks good and the power steering works fine, why touch something that's working? I've never flushed mine in either truck and they're both still full and red (PS uses ATF in these rigs) Link to comment Share on other sites More sharing options...
Kingman Posted May 22, 2009 Share Posted May 22, 2009 I think it's pointless to flush it out unless there is a problem with the system Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted May 22, 2009 Share Posted May 22, 2009 Agreed. My buddy (wannabe mechanic) told me I should do a flush because the PS fluid "looked and smelled burnt". My other buddy (certified Nissan mechanic with 14 years experience) rightfully disproved that remark. If it ain't broke, don't fix it. Link to comment Share on other sites More sharing options...
adamzan Posted May 22, 2009 Share Posted May 22, 2009 Agreed. My buddy (wannabe mechanic) told me I should do a flush because the PS fluid "looked and smelled burnt". My other buddy (certified Nissan mechanic with 14 years experience) rightfully disproved that remark. If it ain't broke, don't fix it. You certainly learned that one well eh. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted May 22, 2009 Share Posted May 22, 2009 You certainly learned that one well eh. Asshat. I cleaned the TB on my R50 because the throttle was sticking. If it hadn't been sticking and filthy with crud, I would've left it alone. Link to comment Share on other sites More sharing options...
Precise1 Posted May 23, 2009 Share Posted May 23, 2009 The ATF used is essentially light duty hydraulic fluid. No, most people never change it. I plan to change mine as it is fairly dirty in my 'new' truck but it hasn't been priority so I'll let you know when I mess with it. The other option is to do the red neck flush. Use a turkey baster or what ever to suck the reservoir dry, refill with fresh fluid and repeat... B Link to comment Share on other sites More sharing options...
Spenceeros Posted May 24, 2009 Author Share Posted May 24, 2009 Good to know, however I don't think my power steering has ATF fluid in it. Link to comment Share on other sites More sharing options...
