flnl Posted August 16, 2004 Share Posted August 16, 2004 My 94 Pathfinder owner's manual says only to tow the wagon from the hook on the passenger side front, and the holes on passenger side rear. Why can't I use the driver's side also? Is there anything to do with the steering? Link to comment Share on other sites More sharing options...
ChromoTech Posted August 17, 2004 Share Posted August 17, 2004 Isnt there only one tow hook on the front?? atleast on mine anyways Link to comment Share on other sites More sharing options...
flnl Posted August 17, 2004 Author Share Posted August 17, 2004 Yeah, on mine there's only one as well. But I don't know where, I saw a photo of one with two hooks, one on each side. So I remembered the owner's manual and I'm wondering why it says not to use the driver's side of the frame for towing... Link to comment Share on other sites More sharing options...
ChromoTech Posted August 17, 2004 Share Posted August 17, 2004 there is two hooks in the back not in the front Link to comment Share on other sites More sharing options...
k9sar Posted August 17, 2004 Share Posted August 17, 2004 I think the intent was to read "only tow using the hook and, by the way, it's on the passenger side" not "only tow using a hook that's on the passenger side, never tow from the drivers side". Stock setup had a tow hook on the passenger side. I removed mine to attach the grill guard. I tow from wherever I want. Link to comment Share on other sites More sharing options...
flnl Posted August 17, 2004 Author Share Posted August 17, 2004 I removed mine to attach the grill guard. I tow from wherever I want. Yep. But that way half of the force will be applied to each side of the frame. Link to comment Share on other sites More sharing options...
Mookie Posted August 17, 2004 Share Posted August 17, 2004 I remember reading somewhere that the drivers side is for tying down and the passenger side is for towing. I've seen alot of people though getting another tow hook from a wrecked Pathy and putting it also on the drivers side frame as there are already threaded holes their. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted August 17, 2004 Share Posted August 17, 2004 That's what I did. The front tow points are the same regardless. Nissan only installed one tow hook and so the manual said to use that one tow hook. Link to comment Share on other sites More sharing options...
ChromoTech Posted August 19, 2004 Share Posted August 19, 2004 my rear stock tow hooks are blocked by my tow hitch so they are useless to me Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted August 19, 2004 Share Posted August 19, 2004 who needs the rear tow points when you got the tow hitch Link to comment Share on other sites More sharing options...
ChromoTech Posted August 19, 2004 Share Posted August 19, 2004 Yea i know Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 22, 2004 Share Posted August 22, 2004 I got another stock hook from the junkyard and bolted it on the driver's side. Works just well on either side, they just don't want you to use the tie-down hole on the driver's side for towing or pulling cause it'll bend under a lot of stress. The tow hook won't, regardless of which side it's mounted on. Link to comment Share on other sites More sharing options...
mudfinder Posted August 24, 2004 Share Posted August 24, 2004 where is a good place to add tow hooks in the back, i don't seem to find a good place for them. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted August 24, 2004 Share Posted August 24, 2004 where is a good place to add tow hooks in the back, i don't seem to find a good place for them. A reciever hitch. Link to comment Share on other sites More sharing options...
Mark Posted September 8, 2004 Share Posted September 8, 2004 From '96 onward they got 2 hooks at the front. Unfortunately, dealers often removed one or both of these hooks when fitting nudge bars / brush guards etc...Easy to fabricate replacements. If ya still got them, The manual says the LH one is "tie-down only" and the RH one is for towing/snatching. Having said that, the two hooks are mirror-image identical. SO: What most guys I know have done is upgrade the bolts on both hooks (just in case) and when they go 'wheeling they shackle an equaliser strap between them. Then they'll tow / snatch from the equaliser strap. Anything to reduce the risk of damage. Link to comment Share on other sites More sharing options...
