fog lights not working
ac92pathfinder
check the connectors as they are in contact with water sun and wind sometimes get dirty (even with the rubber covers ) and make false contact also cables it was a whole day work for me to change the cord because one was broken internally check them with Ohmmeter for continuity from relay to terminal in light and from battery (not connected) terminal to the relay
I change the source from the head light to the corner lights so the condition of head light to be "on" in order to use fog lights was canceled now I just have to turn the quarter lights instead to see if the fog are working :)
This is the original diagram before I modified from my 1990 may can help you or not depends on model but is as it comes from factory in my case
Edited by Ramon
