ac92pathfinder Posted April 28, 2009 Share Posted April 28, 2009 i have a 95 pathfinder and my fog lights arent working i replaced he bulbs the light on the switch lights up and i checked every fuse on the inside. any ideas? Link to comment Share on other sites More sharing options...
unccpathfinder Posted April 28, 2009 Share Posted April 28, 2009 the fuse on the hot lead from the + battery terminal is probably blown...replace it and i bet as soon as you hit the switch it blows again...i had to rewire mine... Link to comment Share on other sites More sharing options...
Ramon Posted April 28, 2009 Share Posted April 28, 2009 (edited) check the connectors as they are in contact with water sun and wind sometimes get dirty (even with the rubber covers ) and make false contact also cables it was a whole day work for me to change the cord because one was broken internally check them with Ohmmeter for continuity from relay to terminal in light and from battery (not connected) terminal to the relay I change the source from the head light to the corner lights so the condition of head light to be "on" in order to use fog lights was canceled now I just have to turn the quarter lights instead to see if the fog are working This is the original diagram before I modified from my 1990 may can help you or not depends on model but is as it comes from factory in my case Edited April 28, 2009 by Ramon Link to comment Share on other sites More sharing options...
ac92pathfinder Posted April 28, 2009 Author Share Posted April 28, 2009 (edited) checked the fuse on the battery its still good and i'll clean the connectors soon Edited April 28, 2009 by ac92pathfinder Link to comment Share on other sites More sharing options...
GrimGreg Posted April 28, 2009 Share Posted April 28, 2009 The factory fogs have a seperate fuse (not in a panel) it is usually in a watertight fuse holder on the power wire to the lights. Link to comment Share on other sites More sharing options...
