Pitman Arm
TxFront
I am in the middle of putting on my calmini steering kit on. The problem I am having is tring to get the pitman arm off. Does anyone have and tricks in getting this dam thing off?
Haven't done mine yet. But I'm going to (hopefully) use a 2 armed puller from Harbor Freight &
if that won't work? A little heat. Afraid of damaging the steering gear box seals though.
What have you tried?
They are often a major PITA, PB Blaster as often as you can, keep it soaked.
Heat while trying to pull it, but as was mentioned, watch the amount due to the PS Box seals.
A 3lb short handled sledge to help break it fee is not a bad idea either.
I have pulled a few and all of them were really stuck on.
I have been hitting the pitman arm with PB blaster and using a pitman arm puller. I am just seeing if there is anything that I am missing.
I really do not want to use any heat on the pitman arm. I know with my luck I will end up messing up the seals in the steering box and I will be worst off than I am now.
I went through 2 days of pounding, and 3 pitman arm pullers when I recently did one. Do yourself a favor and go get a MAP gas torch. Heat that arm up and smack it with a hammer. I did that, and it came off in about 30 seconds.
I had this problem some time ago, I used no heat;
take 2 heavy hammers. (sledges would work great)
PB BLAST
and a pickle fork(tapered end separater) too.
1 givie it Good soak of PB BLAST
2 Positon one hammer against the side of the arm to use as a "bucking bar" and give the opposide side several good smacks with the second hammer. You are not beating the arm off, you are sending a shock thru it and the splines to help it break loose and for the PB to penetrate better.
3 slide the pickle fork in above the arm and drive it in with the hammer
4 if the arm does not budge in a few swings, leave the fork wedged in place (if it will stay) and repeat steps 1&2
I went thru steps 1&3 twice before I could get the arm to come off. But my pathy seems to be really nice to me as far as not having allot of stuck hardware so it may take several more tries on your end.
Edited by MY1PATH
Well hopefully that does work... I had one that both the wrecking yard and I tried to get off. They tried for an 1-1/2 then I took the whole damned thing home and tried using a fork and blunt hits similar to the method you derscribed. Heat was the only thing that got it off.
TxFront - Please keep in mind here that when we say use heat, it does not mean that you are turning the damned thing red or excessively heating the shaft. Apply heat to the *arm* not the shaft, and do so in multiple short periods of time, allowing it to cool in between. This causes the expansion and contraction of the metal arm and will eventually "break" it free from the shaft.
Normally you would just heat both and get it done faster, but in this case you have seals on the shaft to consider, so you have to be careful in how warm to get that shaft ;)
how bout a descent 2 arm puller
the one i bought got the pitman straight off, which had never been off before
buy cheap tools, what do you expect?
Edited by sw
I cut mine off, air grinder with cutting disc and it just fell off (I tried cooking, hammering, heat vision, F-bomb)
finally just 30 seconds of zzzzing and done. carefully of course
I am using the pitman arm puller that you can rent from NAPA
I thought about doing this. After all that is how I got the shafts out of the UCA to put in the aftermarket UCA.
PB BLAST
I like this idea thanks for the heads up. I am going to give this a try tomorrow if not then it will be buzz buzz with the cut off wheel
