tyrhine Posted March 6, 2009 Share Posted March 6, 2009 my pathfinder is starting to shift gears at a higher rpm. I'm sure a tranny flush would help. but is this a sign of a bad thing to come? because I hear all the time about people's breakin on this forums which is making me nervis haha Link to comment Share on other sites More sharing options...
nige Posted March 6, 2009 Share Posted March 6, 2009 are you sure you didn't leave your transmission in the power mode? Its that AT-ET button on the dash. It's also normal for the auto to shift at higher RPM when it's cold. It should also have an abrupt shift between 1-2 gear Link to comment Share on other sites More sharing options...
adamzan Posted March 6, 2009 Share Posted March 6, 2009 Also maybe something is wrong elsewhere. For example when my catalytic clogged, the truck would shift at 3000 grand and barely keep up with traffic. I guess the tranny was just compensating. I also have a rough 1-2 and a slow/soft 2-3. 3-4 is fine though. I've heard that using the nissanmatic tranny fluid solves the rough shifting issue. Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 6, 2009 Share Posted March 6, 2009 I'd definitely try changing the fluid. Do you have an aftermarket external trans fluid cooler installed? If not, GET ONE. The stock cooler clogs up over time and kills the transmission. These aren't cheap trannies, either. Link to comment Share on other sites More sharing options...
tyrhine Posted March 7, 2009 Author Share Posted March 7, 2009 so yea the e-at button was set to power lol. I had no idea what that did! thanks guys I'm still doing a tranny flush because I dun know when the last time the car had one. Link to comment Share on other sites More sharing options...
nige Posted March 7, 2009 Share Posted March 7, 2009 lol glad to hear it was something simple. The e-at button helps out when you towing or super hilly roads. it does a number on your mileage tho. listen to 88 and get a tranny cooler. do a search and there is lots of info on how to install them. They are pretty easy to do. Link to comment Share on other sites More sharing options...
