Nytrosfinder Posted February 26, 2009 Author Share Posted February 26, 2009 I removed it in the cargo area, on the floor pans I left the really stuborn stuff. For the cargo floor I just smacked it with a rubber mallet and it cracked apart for a good bit of it. Then I took a scraper and the mallet and chiseld the rest off. Rhino Liner is the best.... I am thinking about putting that inside my pathfinder once I am done fixing the rust... the only problem I got is that I have subs and I don't know how it will sound... It might rattle or echo or do something weird... all I know is that if my subs rattle my car... at least the inside will hold together... Has anyone ever though of Rhino lining the dash accent pieces? I wonder how or if that will look cool or not.... Link to comment Share on other sites More sharing options...
doubletap Posted February 26, 2009 Share Posted February 26, 2009 Actually there was a thread about that just a little while ago... Rhino Lined interior Link to comment Share on other sites More sharing options...
Kingman Posted February 26, 2009 Share Posted February 26, 2009 Has anyone ever though of Rhino lining the dash accent pieces? I wonder how or if that will look cool or not.... Yes...see doubletaps's comment... Link to comment Share on other sites More sharing options...
GrimGreg Posted February 26, 2009 Share Posted February 26, 2009 Rhino Liner is the best.... I like Line-X a lot better, but neither is a product you can buy and apply at home. I've used Herculiner and Duraliner on my trucks, the Herculiner is much more durable, and has a lot more and larger imbeded rubber particles. Link to comment Share on other sites More sharing options...
DM1975 Posted February 27, 2009 Share Posted February 27, 2009 I plan on putting Herculiner down on my floorboards when I finish welding up the rust holes. I have used it before on a Chevy build and liked it a lot. I just have to get them dang holes patched. My wire welder is a piece of junk with only a high and low setting on the heat and it keeps blowing holes through the metal and I don't think my arc welder would do much more than act like a plasma cutter on that sheet metal. Link to comment Share on other sites More sharing options...
Nytrosfinder Posted February 28, 2009 Author Share Posted February 28, 2009 Once i Finish fixing the holes on my floor pan I will throw some on, then the Lowest 1/2 of my rocker panel I will do it also.... and I am thinking about maybe hitting my frame if I have enough... Friend bought a kit and used a dab or 2 and said he would just basically give me the rest so I am gonna use it for some stuff and hopefully it works out well.... Link to comment Share on other sites More sharing options...
supersayianjim Posted May 12, 2019 Share Posted May 12, 2019 bumping this thread, I have some rocker panel work imma do. Link to comment Share on other sites More sharing options...
supersteve Posted October 28, 2019 Share Posted October 28, 2019 Use thin cardboard to make a template. Self tapping sheet metal screws then flex seal all of it. Link to comment Share on other sites More sharing options...
