CV axle
WiredWrong
i have a 1987 stuck in the woods and i need some help .
I gridded my bearings and the cv axles are broke it half XD
after i dig my self out can I remove my cv axles to get it moving ?
so no front axles , just like a 2wd one
Edited by WiredWrong
Which bearings??
not sure atm it's in 3 feet of mud
when i stuck my hand down there i pulled out chunks bearing
and i can jiggle the cv axle ... i feel the brake in the side of it where the
nuchal is
nuchal is
Ok, those should be the CV bearings, a few large spherical ones. Pull the truck out, disengage the hubs and put the transfer case in 2wd and you should be fine. If you need 4wd low for the rears to get out of the woods, you will have to remove the CVs or hack saw them off at the front differential. :shrug:
Wouldn't it be easier to pull the front propeller shaft out?
