A TBI R/I Question
jmcardamone
Ok. I yanked the TBI off my 87 Cuz I have Made a buddy of mine a Pathfiner Convert today and he wants my 87. Everything is ok, but the gasket on the Spacer Betwen The TBI and the Manifold (not the spacer, Just the Gasket) ripped on the Manifold Side. Can i use a Silicone gasket Sealer and form a gasket, or do i need to purchase the Dang Gasket...
you can ... just make sure that you use a silicon that is impervious to solvents, oils, and gasoline ... I believe that the orange/red stuff will do the trick as it is also a high temp type ...
just be sure that you let the bead of silicon you use gets a little tacky first, and you will be sure to have a good seal ...
  • 2 months later...
