Pathfinder Stereo Problems
dehcho
Hello Everyone.....
What do you think it could be??? Power to the radio no sound, but the occasional crackle. I took it out cleaned all connectors but still nothing. I also took the Amp out and did the same and still no sound.....
Head unit or amp????
Any thoughts????
Thanks
Soooo, you're having problems w/ your 15 y/o stereo... :mellow:
I think it's time you euthanize 'er bubba. She's lead a full life.
Save your pennies, then go down to WalMart and pick-up a VR head unit.
They play USB, SD, CD, DVD (in some cases) and they have a jack int the face to hook up to an MP3 player.
They start at $60 and go up to $400 depending on what they do.
Impressive, cheap, and they beat the hell out of your broken stock one.
I might even have a stereo connector laying around somewhere if you want it. That way you don't have to hack up your harness.
I'll look around if you decide to go that route.
Edited by crazyhayseed
first suggestion... switch to FM
... sorry, had to be said
You can't just get a new stereo and hook into your existing wires. If you get a new unit, you should run new wires to the speakers so you bypass the amps hiding at the back of the truck.
Why not? Mine is running through the stock amps and it sounds great! There is an adapter you buy so its all plug 'n' play. At least it is for mine....
Mine is run through the stock amp. I don't have to turn it up very high to be loud.
I know scosche makes a bypass for the amp, but I can't find it ATM....
You don't have to bypass the amps, but it is sugested. If you plan on using a subwoofer you need to bypass them. If you don't the sub won't be loud. With the stock amps and the amp in the new deck you only have to turn it to lets say 5 of 20 on the volume instead of maybe 16 or 17 for it to get loud. This way the remote wire running to the sub doesn't tell it to play loud enough. You can tweak things around to make it work, but the sound quality will suffer. I got really irritated trying to make it sound good in my old pathy, once I bypassed the amps everything sounded better.
i had the same problem about a year ago with my 92. what i did was check all the backs of the speakers. turns out the problem was that the right door speaker was kinda just hanging there in the door panel. this had put a strain on the wiring behing the actual tweeter. so i did the genis thing of jiggling the wire and reattached it. worked fine after that.
:dance:
I left the stock amps running the stock speakers in the rear. I ran a new remote wire for my sub amp. The head unit I have (pioneer) has seperate output just for subs. If you are going to use the stock speakers in the rear, you might as well just leave them on the stock amp. Personal preference I guess.
Indigent.
