transfer cases different?
bigboy72383
Run into some problems during my 5 speed conversion. There not really problems just wondering about the differance of the 89 transfer and the 95 transfer. When seperating the trans from the transfer found the seal plate for the input shaft was different from the automatic to the manual. Took some pics of the difference.
Here is the plate on the manual,
here is the plate on the auto,
Was wondering what that cup is for at the bottom of the seal and if any body knew if its actually needed?
Also took the electronic speed sensor out of the transfer and sized it up with the mechanical one. Found no obvious reason why they wont interchange because of the spline is the same, same diamater. The only real difference i can see between the two gears is the electronic one is just a hair shorter.
Also the 4wd switch and the neutral switch on the transfer are the same but the 4wd switch off the newer transfer is in a different location but both switches work the same.
I dont want to pull the transfers apart to just change the plate so unless any body has a good reason why switching the speed sensor over to the old transfer and switching the other switches over won't work I'm going to try it out. Thanks for any help anyone can come up with.
I think the difference in the tcases is the speedos...95 is electric and 89 is mechanical...if your not in need of hte 95 speedo internals I would be interested in purchasing those off of you...i'm in the market for a 94 or 95 TC (i'm @ 93505 not sure where your at)...
sorry thats not a lot of help but thats about all i know as far as differences are...
what do you need as far as the speedo internals? (im @37214 on the other side of this rock i think)
The front case covers are in fact different between A/T and M/T models. But I do not see any other differences noted within that year of the manual (1994)
Was wondering if any one knew why the covers are different and if the covers have to be swapped. the only difference I see on the outside is the 4wd switch is in a different location on the newer transfer.
I don't know exactly...but everything as far as the internals (the gears and sensor and what not) to make an electrical speedo work (with the exception of the harness from the tranny to the cluster)
