csutke Posted May 10, 2008 Share Posted May 10, 2008 So I would like to replace my stock stereo but have no clue how to pull the dash bezel on my 04. On my 98 it was easy, two screws and then pop it out. But on this one theres no screws that I can see. Does it just pop off or are there hidden screws? Link to comment Share on other sites More sharing options...
93xe Posted May 10, 2008 Share Posted May 10, 2008 So I would like to replace my stock stereo but have no clue how to pull the dash bezel on my 04. On my 98 it was easy, two screws and then pop it out. But on this one theres no screws that I can see. Does it just pop off or are there hidden screws? If i remember correctly there should still be the two screws on the bottom on both sides, angled slightly downward. Then pull the vent bezel (the top section) off and there will be 2 more screws before you can remove the trim around the radio Link to comment Share on other sites More sharing options...
94extreme Posted May 10, 2008 Share Posted May 10, 2008 Stupid Question Link to comment Share on other sites More sharing options...
TerranoNZ Posted May 10, 2008 Share Posted May 10, 2008 I'm guessing that would be the "Stupid Answer" Link to comment Share on other sites More sharing options...
navygz19 Posted May 10, 2008 Share Posted May 10, 2008 If i remember correctly there should still be the two screws on the bottom on both sides, angled slightly downward. Then pull the vent bezel (the top section) off and there will be 2 more screws before you can remove the trim around the radio Not on later model R50's...there aren't any screws at the bottom. You need to wedge a flathead screwdriver between the HVAC vents and the dash itself to pop them out. Then disconnect the clock. There should be 2 screws visible at that point that you remove, then pop the lower bezel out and remember to unplug the defrost and hazard switches (as well as the AC jack) IIRC, it's easiest to do it with the transmission in 1 to give you more wiggle room. Wait, do you have All Mode on yours? Link to comment Share on other sites More sharing options...
csutke Posted May 10, 2008 Author Share Posted May 10, 2008 Not on later model R50's...there aren't any screws at the bottom. You need to wedge a flathead screwdriver between the HVAC vents and the dash itself to pop them out. Then disconnect the clock. There should be 2 screws visible at that point that you remove, then pop the lower bezel out and remember to unplug the defrost and hazard switches (as well as the AC jack) IIRC, it's easiest to do it with the transmission in 1 to give you more wiggle room.Wait, do you have All Mode on yours? thats all i needed to know thanks, and no I dont have All-mode. Link to comment Share on other sites More sharing options...
