Exhaust/ Headers
pathfinder93x
Hey guys I've been thinking of doing an upgrade to my exhaust...
http://www.4x4parts.com/public_html/shop/i...e0116b0ef91055c
Looking to get those headers with stainless steel exhaust...
Are those headers any good? and I read a couple post about the exhaust on the forums.. I see alot of people get angry with repetition but I was wondering if a 2.5" would be best?
Thank you
Jason
P.S. also whats the cheapest way to get the exhaust replaced while keeping quality? remember i live in quebec... cheap metal= bad
2.5" will give you better top end at the cost of some of your low end torque. You may also notice some backfiring due to lack of back preassure. Borla also makes a 2.5" catback system the sounds great and will not corrode easily I think its like 300usd.
I spent 350usd on Doug Thorley headers; they come nickel coated to prevent corrosion and help disapate heat. Thier 2.25" outlet matched with my 2.25 cat and muffler form magnaflow made for a freeflow system with minimal backfire when engine braking. I wound up making the last bend in my exhaust out of 2" just to hold on to a little more of that low end torque.
most exhaust shops should have aluminzed tubing which lasts allot longer than stock pipes but weigh less and cost less than stainless exhaust. hope this helps.
Those are the Pace Setters. I have them on my 93, I'll buy them for my 88 eventually.
REALLY? I got told $1200NZ for those :blink:
I e-mailed them last night.
Thank you for your interest in our products. The headers have not been tested on right hand drive so I cannot be sure that they will fit right hand drive Nissan.Tubes are 1.25" diameter and main tube is 2" diameter, tubes are not all equal length.
Hmmmm....31.75mm primaries :blink: My ports are 34.5mm :shrug:
