whosfinder Posted March 6, 2008 Share Posted March 6, 2008 (edited) i was looking at the rear end of the truck the other day and it would look cool to have some long arms to the axel from the frame. im not to sure what the exact term is called but i know alot of other trucks use the same type of set up, jeeps in particular. there adjustable with nice looking mounts. thanks for looking.. Edited March 6, 2008 by whosfinder Link to comment Share on other sites More sharing options...
Simon Posted March 6, 2008 Share Posted March 6, 2008 I believe hoohaa had (has) a long arm Pathy, and I believe a couple of the SAS'd folks have had to do it as well. Link to comment Share on other sites More sharing options...
GrimGreg Posted March 7, 2008 Share Posted March 7, 2008 Yeah, most that do it move the lower links up to the top and build a new frame mount further forward, then make new longer bottoms mounted further forward under the frame. Most of the ones I have seen were done by guys on N4W. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted March 7, 2008 Share Posted March 7, 2008 What limit's the rear's articulation is the upper links being how short they are so people make the links longer as said previously. Will also require that you drop down the frame panhard mount to recenter the axle after the lift. Link to comment Share on other sites More sharing options...
packie88 Posted March 7, 2008 Share Posted March 7, 2008 i know spolar did one when he did his sas, and im doing one when i do mine this summer. Link to comment Share on other sites More sharing options...
whosfinder Posted March 9, 2008 Author Share Posted March 9, 2008 thanks guys what front axel you useinf with your SAS set up? i was looking in to the calmini SAS set up any good? Link to comment Share on other sites More sharing options...
packie88 Posted March 9, 2008 Share Posted March 9, 2008 D44 outta a 82 waggoneer. im using parts from calmini just the hanger and bell shackle kit. Link to comment Share on other sites More sharing options...
