long arm rear axel?
whosfinder
i was looking at the rear end of the truck the other day and it would look cool to have some long arms to the axel from the frame. im not to sure what the exact term is called but i know alot of other trucks use the same type of set up, jeeps in particular. there adjustable with nice looking mounts. thanks for looking..
Edited by whosfinder
Yeah, most that do it move the lower links up to the top and build a new frame mount further forward, then make new longer bottoms mounted further forward under the frame. Most of the ones I have seen were done by guys on N4W.
What limit's the rear's articulation is the upper links being how short they are so people make the links longer as said previously. Will also require that you drop down the frame panhard mount to recenter the axle after the lift.
